how to fix 2005 xj8l jaguar power steering oil cooling assembly
Subscribe
Apr 28, 2017 | 05:11 PM
Can someone please give me advice? Greatly appreciate, my steering wheel is completely unmovable.
Reply 0
Apr 28, 2017 | 05:41 PM
What makes you think the problem is the fluid cooler?
Reply 0
Apr 28, 2017 | 05:42 PM
Welcome to the forum CYILV3,
I'll give you some very good advice:
DO NOT MULTIPLE POST THE SAME QUESTION ACROSS DIFFERENT FORUMS
I've deleted identical copies of this from XK8/XKR and Wheels, Tyres, Suspension & Handling forums.
This is the correct place to post technical questions about your model.
Reply 1
Apr 28, 2017 | 05:43 PM
I have it in the shop now and the mechanic informed me of the problem today.
Reply 0
Apr 28, 2017 | 05:58 PM
Looking quickly at the power steering system diagram, it doesn't seem like the fluid cooler would be too difficult to replace. Used ones are pretty cheap on ebay also.
Reply 2
Apr 28, 2017 | 06:09 PM
Thank you for your reply. I have spoken with two other Jaguar mechanics. What diagram are you reviewing can you post a pic?
Reply 0
Apr 28, 2017 | 06:14 PM
Here you go:
how to fix 2005 xj8l jaguar power steering oil cooling assembly-x350-power-steering-layout.jpg
Reply 2
Apr 28, 2017 | 06:24 PM
2005 xj8l power steering oil cooling assembly
Two mechanics are saying it is difficult to assemble because you have to remove major components of the engine. I have to install Part 4 of the diagram.
Reply 0
Apr 28, 2017 | 06:29 PM
According to the repair manual, they're trying to fleece you. Check out the attachment. This job should take under an hour.
Reply 2
Apr 28, 2017 | 06:31 PM
Do you think you can give me directions to have it done.? I have a friend that may probably be able to do it with some guidance. I have been unable to find a video of the repair.
Reply 0
Apr 28, 2017 | 06:35 PM
The document I attached is taken directly from the repair manual. Just follow those steps. The entire workshop manuals can be downloaded here:
https://www.mediafire.com/?x11yhijup29yt#8viyccmusy9t1
Reply 2
Apr 28, 2017 | 06:39 PM
Thank you so very much! I will have my car towed to my friends house tomorrow. I greatly appreciate you taking the time to help me!
Best regards,
CYILV3
Reply 0
Apr 28, 2017 | 06:40 PM
It's shameful those "mechanics" would lie to you like that. Pisses me off.
Reply 1
Apr 28, 2017 | 06:42 PM
Again thank you! That was more than expected.
Reply 0
May 10, 2017 | 10:11 PM
Update:
Thank you again for your generosity with all the information you provided. My friend was able to do the repair and everything is working wonderfully.
Reply 1
May 13, 2017 | 08:59 PM
CYILV3,
Thank you for reporting back with the resolution of your issue. What was the diagnosis of the old cooler? Was it clogged?
XJ8JR,
Thanks for the posts and information that helped resolve the problem!
Cheers,
Don
Reply 0
Jun 27, 2017 | 05:28 PM
old cooler
Yes! It was severely damaged and worn out! I have replaced quit a few items: All control arms front and rear along with new tie end rods and sway bars. Everything appears to be going well mechanically.
My next tackle is to check fuses for my seats. They are not operating fully.
Thank you Again!
Reply 0
Subscribe
Currently Active Users (1)
