how to fix 2005 xj8l jaguar power steering oil cooling assembly
Old Apr 28, 2017 | 05:11 PM
CYILV3's Avatar
Default how to fix 2005 xj8l jaguar power steering oil cooling assembly
Can someone please give me advice? Greatly appreciate, my steering wheel is completely unmovable.
Old Apr 28, 2017 | 05:41 PM
XJ8JR's Avatar
What makes you think the problem is the fluid cooler?
Old Apr 28, 2017 | 05:42 PM
Welcome to the forum CYILV3,
I'll give you some very good advice:
DO NOT MULTIPLE POST THE SAME QUESTION ACROSS DIFFERENT FORUMS
I've deleted identical copies of this from XK8/XKR and Wheels, Tyres, Suspension & Handling forums.
This is the correct place to post technical questions about your model.
Old Apr 28, 2017 | 05:43 PM
CYILV3's Avatar
I have it in the shop now and the mechanic informed me of the problem today.
Old Apr 28, 2017 | 05:58 PM
XJ8JR's Avatar
Looking quickly at the power steering system diagram, it doesn't seem like the fluid cooler would be too difficult to replace. Used ones are pretty cheap on ebay also.
Old Apr 28, 2017 | 06:09 PM
CYILV3's Avatar
Thank you for your reply. I have spoken with two other Jaguar mechanics. What diagram are you reviewing can you post a pic?
Old Apr 28, 2017 | 06:14 PM
XJ8JR's Avatar
Here you go:
Attached Thumbnails how to fix 2005 xj8l jaguar power steering oil cooling assembly-x350-power-steering-layout.jpg
Old Apr 28, 2017 | 06:24 PM
CYILV3's Avatar
Question 2005 xj8l power steering oil cooling assembly
Two mechanics are saying it is difficult to assemble because you have to remove major components of the engine. I have to install Part 4 of the diagram.
Old Apr 28, 2017 | 06:29 PM
XJ8JR's Avatar
According to the repair manual, they're trying to fleece you. Check out the attachment. This job should take under an hour.
File Type: pdf
Old Apr 28, 2017 | 06:31 PM
CYILV3's Avatar
Question how to fix 2005 xj8l jaguar power steering oil cooling assembly
Do you think you can give me directions to have it done.? I have a friend that may probably be able to do it with some guidance. I have been unable to find a video of the repair.
Old Apr 28, 2017 | 06:35 PM
XJ8JR's Avatar
The document I attached is taken directly from the repair manual. Just follow those steps. The entire workshop manuals can be downloaded here:
https://www.mediafire.com/?x11yhijup29yt#8viyccmusy9t1
Old Apr 28, 2017 | 06:39 PM
CYILV3's Avatar
Thumbs up how to fix 2005 xj8l jaguar power steering oil cooling assembly
Thank you so very much! I will have my car towed to my friends house tomorrow. I greatly appreciate you taking the time to help me!
Best regards,
CYILV3
Old Apr 28, 2017 | 06:40 PM
XJ8JR's Avatar
It's shameful those "mechanics" would lie to you like that. Pisses me off.
Old Apr 28, 2017 | 06:42 PM
CYILV3's Avatar
Red face how to fix 2005 xj8l jaguar power steering oil cooling assembly
Again thank you! That was more than expected.
Old May 10, 2017 | 10:11 PM
CYILV3's Avatar
Update:
Thank you again for your generosity with all the information you provided. My friend was able to do the repair and everything is working wonderfully.
Old May 13, 2017 | 08:59 PM
Don B's Avatar
CYILV3,
Thank you for reporting back with the resolution of your issue. What was the diagnosis of the old cooler? Was it clogged?
XJ8JR,
Thanks for the posts and information that helped resolve the problem!
Cheers,
Don
Old Jun 27, 2017 | 05:28 PM
CYILV3's Avatar
Smile old cooler
Yes! It was severely damaged and worn out! I have replaced quit a few items: All control arms front and rear along with new tie end rods and sway bars. Everything appears to be going well mechanically.
My next tackle is to check fuses for my seats. They are not operating fully.
Thank you Again!
