Hydraulic lifter tick
On my 2004 jaguar xj8 with about 105k miles I have noticed it has a ticking sound coming from the passenger side of the engine that sounds exactly like lifter tick. I put motor honey in it too thicken the oil and that did quiet it down but it still ticks.
has anyone else here on the forums had an issue with the hydraulic flat tappet lifters failing? According to the research I’ve done our engines don’t have valve buckets they have hydraulic flat tappet lifters. This vehicle sat for a long time so most likely that lifter was compressed for that entire duration and not only that the car used too have a pretty bad oil leak before I got it so I am sure it ran low on oil before in its life.
this I am sure is gonna be an expensive repair as the camshafts have too be removed too replace the failed lifter.
it’s not as bad yet but it definitely has lifter tick. How common is it for our engines too get lifter tick?
Ah okay after your post and reading the engine assembly service manual you are 100% correct. Now I put 20W-50 and Lucas high mileage oil stabilizer this tick is completely gone. What do you think has failed it definitely sounded top end and like valve tick
Perhaps the valve lash needs adjusting after years of use?
Did you read through the Engine Course 168 I had copied from my Jaguar Training?
I had it in paper form but went to a COPY STORE and had converted to .pdf.
It is all over the internet as well as jagrepair.com.
I also had my WDS training guide converted as well.
Jaguar did issue some documents in .pdf from the early 2000s but before that it was PAPER ONLY.
It might be worth pulling a cam cover to inspect, the cam lobe may be damaged or worn if it now has excessive clearance. The other item that is known for ticking is the VVT actuator. There's a locking pin or something that wallows out its hole and ticks on cold starts. There's old threads with photos of this.
I now also have a misfire codes on cylinder 5 and 7 randomly only when the engine is hot if I start the car it will idle rough for a couple seconds and run completely fine also when I floor it I do notice that it sounds like it’s misfiring at the high RPM band
Also not that the car is slow or anything but for an almost 300hp rated car it definitely does not feel like it has the get up and go that it should especially in the higher gears loading the engine around town.
princemarko
Nov 4, 2021 01:24 PM
