Intermittent whine
Old May 10, 2021 | 06:19 PM
meirion1's Avatar
Default Intermittent whine
In the 'old days' a failing wheel bearing would rumble but do
modern ones whine?
Old May 11, 2021 | 01:18 AM
ChrisMills's Avatar
Free method. I'll start again.
Nearly Free method. Take it for a "warrant of fitness". Those b'tards are getting tight and failed two of my trailers, even though my trailers only do a few k a year. Corrosion?: BS wheel bearings are enclosed.
Technology of wheel bearings hasn't changed much as far as I know. It cost half the cost of my trailer to have new wheel bearings put in, so yes, modern Kiwis whine.
I never thought of DIY. Whassat?
Old May 11, 2021 | 09:21 AM
Six Rotors's Avatar
The technology has changed----in the old days most wheel bearings were adjustable taper roller bearings whereas today most are non adjustable sealed angular ball bearings. My experience with Subarus and on 2006 Vanden Plas is that they make a whine, increasing in volume and pitch as vehicle speed increases. Often they make noise before you can feel any looseness in the bearing.
Old May 11, 2021 | 05:10 PM
meirion1's Avatar
Thanks for sharing that Six Rotors!
Old May 11, 2021 | 09:14 PM
xalty's Avatar
spin the hub with no wheel on
should be silent
Jagm1979
Aug 28, 2014 09:51 PM
lovemycar1
Aug 4, 2011 07:28 PM
Jag69
Mar 17, 2011 09:33 PM
