Jack & Jack Stand Placement 2004 XJ8
Old Jan 12, 2021 | 12:32 PM
djpxk8's Avatar
Angry Jack & Jack Stand Placement 2004 XJ8
I am about to replace my air suspension with the Arnott C-2745 Coil over conversion kit and would like some help as to where to place the Jack for the front and rear and also where to place the jack stands to be safe! Any diagrams or pictures would be most welcome.
Old Jan 12, 2021 | 05:19 PM
Pete M's Avatar
Here is the diagram from the manual
Old Jan 12, 2021 | 09:12 PM
djpxk8's Avatar
Thank you very much for your "instant" reply, that is just the picture I needed...THANKS!!!!!
Old Jan 25, 2022 | 03:10 PM
MaxTorq's Avatar
so if i am interpreting this pic correctly then the forward black dots are frame points that are ok to use as jack stand points also ?
max
Old Jan 25, 2022 | 03:56 PM
Pete M's Avatar
max
I think that's probably correct as far as strength goes, but the jacking and stand points are probably separated so a corner can be jacked up and a stand placed without the jack getting in the way. That's how I did it when I took all my wheels off for refurbishment. I'm not sure if you can use the outermost points front and back as lifting points for a two or four point hoist. My inspection agency uses a drive-on lift with front and rear lift elements that go under each subframe to unload the wheels as required for checking.
I found that the body was so rigid that lifting one corner slightly higher on the stand meant that the other side was unsupported by its stand. It was like that for a week, and didn't change at all. The X350 is a very tough body.
Pete
Old Jan 25, 2022 | 08:19 PM
Wingrider's Avatar
A hockey puck on the floor jack, will add a soft touch, to which ever point you chose.
Old Jan 25, 2022 | 08:27 PM
MaxTorq's Avatar
THANK YOU PETE n WINGRIDER !
dont know if it was ok but used the front cradle cross member to jack up the front end (slowly) and it seemed strong enough.
i used a block of wood under the diff to jack up the rear
...a lotta work to do...
max
Old Jan 25, 2022 | 11:31 PM
Sentinelist's Avatar
Great tip- I should have been using one on mine long ago. Will start doing so with my XJ that I haven't jacked yet! Just ordered one off Amazon as soon as I saw this. 'Inglasco Official Ice Hockey Puck Black 6 oz.' $7.49 USD.
Old Jan 26, 2022 | 04:14 AM
paydase's Avatar
max
Seems to me that the front craddle cross member is hidden behind the bolted plastic underpan. How could you use it?
Also I would avoid jacking the rear using the diff.
The jacking points indicated by Jaguar are well suited and accessible.
Old Jan 26, 2022 | 07:25 AM
Wingrider's Avatar
Keep 4 in each trunk for use with the lift at my friends shop.
And those for my floor jacks at home, cheaper by the dozen.
Hockey Monkey, about $20 a dozen, plus tax & shipping.
Old Jan 26, 2022 | 01:50 PM
aceler8's Avatar
be a tough decision to use my Carolina Hurricanes puck, but dang good idea!
Old Jan 26, 2022 | 02:16 PM
MaxTorq's Avatar
Thank you !
max
Old Jan 26, 2022 | 03:44 PM
MaxTorq's Avatar
Let me share a caution while using some of the pucks…
I purchased the cheapest set I could find on amawho.com
they are solid but very hard (a good thing) however… I did not consider that made them a little smooth/slippery too.
First use on the quickjack and they slipped off of the other locator blocks.
‘luckily no damage but def a near miss experience.
In the future, I will use them but with more caution for now on.
max
Mrjay622
May 29, 2022 05:32 PM
Goldlion
Dec 31, 2009 02:03 AM
mosesbotbol
Dec 11, 2008 07:25 AM
