Jack Points
Old Oct 10, 2008 | 06:11 AM
mosesbotbol's Avatar
Default Jack Points
Does someone have a picture of where to put a floor jack under 2004 XJ8? I would like to pull off the wheels and wasn't sure where to jack the car from...
Old Oct 12, 2008 | 03:08 PM
oldmots's Avatar
Default RE: Jack Points
This car has micro sizedjackpoints! Right behind each little bulge in the rocker panel seam where the jack in the trunk fits, there is a bare metal area, jack there. If you have a special jack with a sort of nubby phallus on it, it fits in a hole in this metal area. I think the shops use this special fitting to keep the car on the derned lift. Look out in the rear, if you miss the jack point even a little, the jack will bend the lower sheet metal radius arm for the rear suspension, and you might be crabbing sideways from then on. I could bend these things over my knee! Reminds me of the arms on my Lotus Europa. I think this was just a little too light for practicality, they are going to get bent sooner than later.
jagent
Jun 5, 2022 02:18 PM
magmedia
Aug 15, 2019 08:54 PM
mjm3457
Jan 30, 2018 09:02 AM
BSM
Sep 25, 2015 05:00 PM
Collector1
Sep 25, 2015 11:27 AM
