jag tech needs advice from other techs on x350 problem
Old Sep 4, 2008 | 06:38 PM
langerdan's Avatar
Default jag tech needs advice from other techs on x350 problem
i have a 04 x350 that intermittantly all lights come on dash gear selector wont come out of park,gearbox fault is displayed abs fault is displayed suspension goes hard, steering goes hard car basicaly goes into limp home mode as i said this is an intermittant fault
all faults showing up on ids are can busrelated faults, iam aware of a tsb regarding connector pin retention on the can bus circuit however this car id displaying different faults listed in the tsb also my car is out side the chassis range listed in the tsb
another tech has told me that he once had a similar problem and the cause was a faulty instrument cluster has any other jag techs experienced a fault like this
its hard to diagnose when its so intermittant
also ive checked resistance on the can network and it appears to be fine
Old Sep 7, 2008 | 05:37 PM
oldmots's Avatar
Default RE: jag tech needs advice from other techs on x350 problem
As you probably know, all the problems you report are linked by the CAN network. The instrument cluster, the dynamic stability control module, which controls the steering angle sensor, the ABS, the J-Gate module, the air suspension module , and so on. The signs you have are of a classic bad connection or harness fault. All these modules are not bad. I am no tech, but I would start wiggling wires and checking harnesses in the CAN bus. Even if the car is out of the TSB range, it could still be related to the TSB.
Old Sep 10, 2008 | 02:34 PM
langerdan's Avatar
it looks like itwas a bad connection on the can network i went through all can network connectors and secured them and problem has not yet reoccurred only time will tell i supose
Old Sep 11, 2008 | 09:06 PM
oldmots's Avatar
When I get a fault like this, I get mad and start grabbing harnesses and pulling them hard with the car running, like grabbing the cat after he claws your favorite chair! If it's going to do it, it will do it then. I just watch for signs of a failureduring each pull. I try to narrow the work area by finding out who has been in there before and where they were. The problem is often due to a ham-fisted tech working on something else, opening a connector and not pushing it home before buttoning up the car.
Old Sep 11, 2008 | 09:42 PM
JagtechOhio's Avatar
Hey mots,
I guess that clears the way to call you an applesauce-fisted do-it-yourselfer?
Old Sep 14, 2008 | 10:35 AM
jag_genius's Avatar
had similar problem found ip faulty. Also had one trunk fuse box water damage causing all sorts of weird intermittent things. Doesn't huurt to take a peak
X_Type_South_Africa
Dec 9, 2015 05:37 PM
jdzubas
Oct 4, 2015 09:14 AM
thedugger1
Sep 24, 2015 05:32 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
kesslari
Aug 27, 2015 06:26 AM
