Jaguar XJR x358 O2 sensor faults - help!
Old Jul 7, 2020 | 02:28 PM
caldoofy's Avatar
Default Jaguar XJR x358 O2 sensor faults - help!
Hi all,
Hoping for a bit of help here, I have done extensive searches but have not been able to identify any similar conditions.
So, I had initially codes P0031,P0051, P0131 and P0151 all relating to upstream O2 sensors low heater circuits and low sensor circuits.
I got under the car and tested the sensors one had infinite resistance i.e. toast and the other resistance of 9 ohms so I bit the bullet and bought two genuine denso sensors and fitted them. Was now getting stft feed back from both sensors and car running well so great, I thought, problem solved.
Fitted them Sunday gone (5th July) and today on way home from work car into restricted performance and sounding like it's running on four cylinder's. Got home ran a scan and sure enough the previous P codes are back 😠.
Read up on earths and redid ground point g3 and snapped the stud so I thought maybe it was a bad earth, put a new earth point on but still the same.
Checked fuses 33 and 34 both showing battery voltage which I think rules out relay 12.
So my question is are the O2 sensors earthed to a different point as I see a reference to the grounds behind the strutt towers but then both grounds would have had to failed at the same time !?
Anyone got any ideas?
As the title says - HELP!!
Old Jul 24, 2020 | 05:25 AM
caldoofy's Avatar
Default Fixed
Well for closure and others that may search this topic I found the problem to be the earth points behind the front suspension turrets. Once cleaned and put back together O2 sensors came back to life and been ok since.
Old Jul 24, 2020 | 05:58 AM
jerry_hoback's Avatar
Sorry o couldn't help. Thanks for the resolution. It will help in future.
Doug Dooren
Jun 29, 2019 11:51 AM
Red October
Feb 9, 2015 06:32 AM
FlamurAdili
Jul 15, 2014 04:41 PM
lsp
Dec 28, 2012 02:19 PM
etaent
Feb 24, 2012 12:19 PM
