Left Front Brake noise
Old Feb 14, 2010 | 06:19 PM
robinakirk's Avatar
Default Left Front Brake noise
So my 2008 XJ8L makes slight "groaning or Clunking" noises when braking at slow speed just from the left front. It seems to come from just forward of my left knee. There is no vibration or loss of braking function.
Does anyone know what it is causing it?
Thanks.
Old Feb 15, 2010 | 02:18 AM
the-pm's Avatar
Are you turning when it happens (i.e. into a side road and so are slowing and the turning the wheel)? I had this with my 2006 XJR and the dealer found that it was just that the brake callipers had not been greased very well and it would make a groaning or clunking. Easy fix as they took out the pads, cleaned it up and applied a good dose of copper grease and it fixed the problem.
The way to check is find a quite road with no traffic and do about 10mph, then lightly left foot brake and apply pressure on the accelerator to maintain the speed and turn the wheel from left to right and will hear it clunking if it is this issue. Don’t do this for long or you will burn your brakes out but it only takes a couple of seconds to perform the test.
Philip
Old Feb 15, 2010 | 05:09 PM
robinakirk's Avatar
Thanks Phillip. It does only happen when turning, so I will have the dealer look at that when I take it in.
Old Jun 26, 2010 | 09:44 AM
tlombard77's Avatar
Sounds a lot like a problem I am having which the dealer cannot figure out.
Old Jun 30, 2010 | 01:58 AM
2004xjr's Avatar
I have same prob. Did new pads and roters. And a new left wheel bearing.
Still there... OMG make me crazy!!!
I will try the brake test in morning. I will try anything!!!
Brian.
Old Jul 2, 2010 | 12:57 AM
digibrock's Avatar
I have a similar problem, that is somewhat related to braking, but is mostly heard when turning and braking, like when I pull into my driveway. At first I thought I had a bad control arm bearing, but I have isolated the problem to... of all things... the hood/bonnet. Push down on the hood around the left side near the windshield and see if you get "the sound". My understanding is that when the hood is closed, there's some contact between a couple pieces of metal and that the small amount of flex in the body when turning or braking is enough to cause the noise. I remember casually reading about this on what I thought was jaguarforums long before I had the issue. Unfortunately I haven't been able to find the post yet. I remember the post indicating that the problem was inadvertently found when he was waxing the hood. Ultimately he used some bearing grease to fix the problem.
Of course this may not be the same noise you're experiencing, but worth the 5 seconds it takes to check out.
Old Jul 2, 2010 | 01:10 AM
digibrock's Avatar
Ok, I found the thread about the hood problem creating the sound in the left front. Check out this thread, and look at posts 18 and 23.
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
innzane
Sep 2, 2015 10:08 AM
