Need help replacing glove box actuator
After mine failed, I purchased a replacement unit on eBay, but am unable to get the old one out. I pried off the wood passenger airbag panel and was able to remove the 6 Torx screws securing the actuator, but there is not enough room to remove it through the space between the dash opening and bottom of the airbag canister. I also removed the glovebox but it is not the problem. Any suggestions? Thanks.
WaterDragon
Aug 21, 2016 03:17 PM
