need instructions to replace front brake pads, also a good source for them
Old Jan 29, 2009 | 08:57 AM
Plant's Avatar
Default need instructions to replace front brake pads, also a good source for them
2004 XJ8, need to replace front pads. Can you help with directions and a good source for buying the pads besides a dealer?
Thank You.
Old Jan 29, 2009 | 01:32 PM
mosesbotbol's Avatar
Default RE: need instructions to replace front brake pads, also a good source for them
I ordered the Akebono pads from Rock Auto and they work really well. Not much dust at all like a Japanese car. Most likely you'll have to replace the rotors; they do not grind well if at all.
I'd go with OEM rotors. Rock Auto had the wrong size and price difference between OEM and other brands was very little.
My independent Jag repair place only like to use OEM pad/rotors as they say they usually run into chattering, squeaks, etc... and was suprised the Akebono's did not have issues.
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
jdzubas
Oct 4, 2015 09:14 AM
ronald4313jm
Aug 31, 2015 07:58 AM
Rhett
Aug 28, 2015 11:30 PM
