New here..
Old Dec 8, 2009 | 03:35 PM
H20boy's Avatar
Hard to say on a 2-3 year old XJ, but if it still has the air shocks and suspension system (I think it does) that may be an issue down the road.
Super V8 = fast
Sounds like a nice car. As for keeping the factory stereo and nav together, there's not many products that will integrate, but Kenwood's CarPortal system is claiming they can tap into the existing video screen, allow OEM deck operation, in addition to allowing all the other audio/video add-on capabilities. Sub upgrades are also limited in a free-air system, but there are some options out there...kicker does them, and i've read some good reviews after upgrading. New component speakers are probably the easiest aspect of the car you'll have to deal with.
good luck.
Old Dec 9, 2009 | 08:20 AM
Drew's Avatar
I used a line out converter for the amp and two subs I installed a week ago. I do believe the system's amplifier is in the trunk on the left side. It's just in front of the nav and cd changer. The factory unit is pretty loud especially if you add some more bass. I think you might have a problem with raffling if you add it much. You will also have to decide the placement for the component and disconnect the two dash speakers. The stock tweeters are very small, so pay attention to the size of the aftermarkets you buy, unless you are drilling. The trunk does work for an easy amp install. There are several factory grounding point and the battery is in the trunk. Also, the factory amp is like 40 watts by 8, so make sure your line converter can handle that wattage.
Hex Type
Jun 4, 2015 08:18 AM
ofis
E type ( XK-E )
Jun 3, 2015 02:40 PM
isuralife
May 26, 2015 01:09 PM
JagVonder
Oct 28, 2014 08:29 AM
bodykits
May 6, 2009 04:55 PM
