New to Jaguar Forum
Old Jan 19, 2018 | 05:31 PM
harlankatz01's Avatar
Default New to Jaguar Forum
I have a 2005 XJR and the interior fan doesn't work. from Low to high and auto do not work. The touch panel works. Also the blend doors work when you push the buttons. Any suggestions?
Old Jan 19, 2018 | 06:16 PM
XJ8JR's Avatar
Perhaps a fuse?
Old Jan 19, 2018 | 11:55 PM
I'll let you know tomorrow.
Old Jan 20, 2018 | 06:10 AM
Fraser Mitchell's Avatar
It is probably the fan control module that fits on top of the fan unit. It is a fairly easy job to fix and not too expensive, but the glove box has to be removed to get at the fan unit. The module screws in the top of this and has cooling fins that stick into the air flow. Later control modules had longer fins so the problem was related to heat damaging the module.
Old Jan 22, 2018 | 08:21 AM
thank you. need to remove the glovebox and figure it out. Fuses are all good. I'll let you know what I find.
adam699
May 11, 2015 04:59 PM
eieio
Feb 12, 2013 02:20 AM
sandydlc
Aug 10, 2011 07:47 PM
XJ8Long
May 6, 2011 06:21 PM
Platinum Sport
Apr 2, 2011 07:34 AM
