New potential purchase
Old Feb 27, 2021 | 10:55 AM
CA Jag's Avatar
Originally Posted by RoadMaster2
Mr. Bob -
I'm owner of a 05 Super V8 bought 3 years and 20,000 miles ago with 134,000 miles. I paid 7,200 $. I don't do my own work but have a great and reasonably priced mechanic (90/Hr).
I'll be brief for once. Had I known in reality what I know nor through experience, I would not have paid over $5,000 for my car, especially given the generally low prices of vehicles that have been well cared for or had all the neglected maintenance performed.
Mine had an intermittent suspension fault lite on at purchase. In addition it had worn bushings front and rear, uneven wear on the front tires, bent rims, and alignment issues. I did not have a pre purchase inspection. I don't think it would have mattered, I love the car and bought it away from where I now live.
Over the next 2 years I fixed them all, but started with bypassing the ECATS air system. I wanted to drive the car, not continue to fix the same problem multiple times.
Now that all is resolved ride wise, the car drives like no other, even w/o the air. The only irritating thing is that even after doing all the suspension work and replacing the air shocks with Eibach springs (1,000$) my car rattles over a light rough road so commonly encountered in daily driving. Frustrating but not a deal breaker. The car is finally safe to drive!
And even my American car loving Mustang / Chevy / Dodge Truck driving mechanic now loves my piece of Euro-trash.
FCP Euro sells an entire rear Lemforder kit for $500, and the front parts- wishbones, upper and lower control arms, tie rods, sway bar links, etc are about 1,000 total also Lemforder ar FCP Euro.
My car also had a frozen front caliper, and refurbished were not to be found. So I ended up spending on new calipers, slotted rotors, and Akebobno pads. The aluminum calipers were $700 EACH, so that was a big ouchy repair.
The other big thing to look for is coolant issues, hoses condition, coolant smell, as this is a common issue and can ruin a car. My supercharged version did ultimately have a coolant leak in the "Valley Hose)(underneath the S/C - hard to get at, so costly to repair. The day it happened I drove it on HOT over 2 hours, then again that same day in the same condition 2 hours home. From the comments on this forum, I may be the luckiest Jag owner on earth as my motor should have been damaged.
I do believe that this over heat caused my heater core to get clogged so I now have uneven heat flow even though the auxiliary water pump and door actuators have been replaced.
This last heater core problem is very common as well. My car heats, but flow is uneven. And along that note - I hear it gets HOT in Stralia from time to time, so make sure the car blows cold. Mine didn't this past summer but now that the actuators and H2O pump are fixed I'm hoping its better. It did cool during our very extended hot weather this fall in O-H-I-O.
Get the car checked out and don't buy it if a lot of regular maintenance has been neglected. I have not had to do anything weird repair wise as many people think Jags have oddball problems. I just had to do more neglected maintenance than I thought. It is very expensive to play "catch up" whether you do your own work or not so be prepared to wait for another better example. There are lots of great values out there - a few of which are listed on our forum!!!
And even after all this - I'm looking for an XJS. Jags bite really hard. Be careful out there!
Best Regards
Mike D.
Hi. Can relate to your comment about Jags bite. Recently bought my first Jag. Nice convertible that looks perfect. I've owned many cars. I always do a pre-inspect and also have a mechanic look it. Long test drive. Verify service history (and needs to be well cared for). For this one, looks won out over common sense. Repair estimates are 4k. I'm sure there will more costs. In the meantime, also looking for a really nice example.
Old Feb 27, 2021 | 09:27 PM
Bob Hornby's Avatar
Originally Posted by Bob Hornby
My Cobra is almost sold so I am searching for a XJ6 X350 and I have found one (2007) in Victoria (I am in NSW). Should I go ahead with this I will certainly get a mechanical inspection and if all is basically OK then we are off and running. BUT, I have been reading in this forum about the issues with the air suspension.
Question 1
Is there something specific I can ask the inspecting mechanic (he/she may not be a Jaguar mechanic) to look for ?
Question 2
Does the air compressor or air bags fail suddenly to the point of not being able to drive the car? or do symptoms occur that allow the car to be still driven ?
Thanks in advance, Bob
So far so good, the Cobra is sold and I got what I hoped for, Now to take looking for a Jag very seriously. I have looked at one in Melbourne an X350 (2007) at a dealer, they are asking $37,000 for it but have indicated there will be some room for negotiations. It has done 118,000 km's so not too many. If the suspension units have been renewed then they should be sweet. However it is of course possible that they are still the originals.
Bob
Old Feb 27, 2021 | 10:22 PM
xalty's Avatar
call a junkyard and get s-type struts
problem solved
Old Feb 27, 2021 | 11:20 PM
ChrisMills's Avatar
I'm astounded. Less than half that price in NZ.
Couldn't see many for sale though. Carsales . com. au put a value between $14k and $17k but I know nothing about that site.
I was going to get an Aussi insurance quote to see the value range, but they asked too many questions.
Bear in mind that nice as it is, it's a base model XJ6, and for instance doesn't have heated/cooled seats. Just sayin'
Old Feb 27, 2021 | 11:52 PM
Bob Hornby's Avatar
Thanks for that Chris, I hadn't thought about getting an insurance
Bob
Old Feb 28, 2021 | 12:09 AM
RoadMaster2's Avatar
Bob -
I don't know about values in your country, but if that's $37,000 US dollar equivalent or even close, then that car is either truly perfect and nearly new with super low miles, or it is really just overpriced and the dealer looking to max out profit by finding the right person.
Just my 2 cents.
Mike
Old Feb 28, 2021 | 04:58 AM
meirion1's Avatar
$37000 aud = $28.5 usd
It is expensive
My Jag is 2004 V8 with 102k MILES and might be worth ~ $15-16k AUD
Old Mar 1, 2021 | 05:24 AM
  #28
Bob Hornby's Avatar
Does the 2009 X358 have the air suspension?
Bob
Old Mar 1, 2021 | 12:46 PM
ChrisMills's Avatar
Bob
Yes.
The X351 2010 onwards has air suspension in the rear only, which seemed like half admitting defeat.
P.S. there has been a suggestion that if you change to coil springs, an insurance company might regard it as a modified vehicle. I don't personally know, just that insurance companies will find any excuse...
Also (not sure if it's relevant due to country), but my Autosure mechanical insurance (not really worthwhile IMHO) specifically covers "Active Suspension", but beggar me it does not cover worn bushes!!! (at 89k) Jaysuss, damn near anything could be considered "normal wear and tear" from their point of view.
And in the exclusions - read this twice - "Any breakdown caused or contributed to by a manufacturing error..."
Shaun Walker
Aug 11, 2020 07:36 PM
BDuncan
Mar 15, 2019 06:21 AM
