Also removed side moldings. I own Acme Wheels & Tires and We just got on board with Verde and I fell in Love with the Axis V99. I went with stagger 19x8.5 and 19x9.5 with Lionhart LH Five in 275/40 at all 4 corners. Finally got to install our caliper restoration decals too. LOVE this look and ride. The center caps are aluminum.
Reason: Deleted commercial content.
Your Jag looks fantastic - the newer style rims really update the look and the color matches the car perfectly.
It's amazing to me how much cleaner and different the car appears without the side moulding.
Question - The Lionhart Brand is a less expensive Chinese made tire yes? Do you have extensive experience with this brand and how they perform short and longer term?
I have a 2005 Super V8 and have been on almost a year now without posting pics. I have several sets of OEM wheels and your car looks so good I really need to share mine. It's irritating when people don't have pics I find.
Hi OnebadassXJR,
Awesome looking car, great wheels, the color of them match the car so well.
I assume that Lionhart tires are Chinese, and it sounds like they are good performers.
I recently had my badly kerbed Callisto 20 inch wheels repaired and have fitted Triangle tires, again Chinese.
I will be interested to see how the tires perform in the long term. Are Triangle tires available in the USA?
Assymetric tread Triangle brand Correct size and load rating Fitted to the car
Question to the PO: why did you choose to have a staggered rim set with same tires' width front and rear?
Also 8.5" for a 275 looks to me to be on the low side...
I got a good deal on the 4 in same size and I love the staggered look, the back is more concave. They also didnt have a larger size for the rears in the LH5 that had the same sidewall.
It's not uncommon to have staggered rim sets with same tires' sizes (wider rims on the rear).
It may have a slight impact on the handling, wider rims procuring a sharper response of the tires, thinner rims a more sluggish one.
But in your case the quite wider tires (275 compared to the 255 original fitting) also will modify the handling.
Overall did you notice a difference in handling?
