New smitten 2005 Super V8 owner with some questions (pics inside for your answers!)
Old Jan 6, 2022 | 06:42 PM
  #41
luv2fly's Avatar
Nautivan, I just put these, PIRELLI CINTURATO P7 AS NCS TIRES on my 09 SV8 Portfolio. I've been running the P7 All Season on everything I own and zero complaints. Sorry for the caps, cut and paste from my maintenance log.
Old Jan 6, 2022 | 06:47 PM
  #42
luv2fly's Avatar
Sentinelist, a couple of weeks ago you could still get the latest 2011 Nav disk directly from Jaguar Navigation. $200. I put it on my list as not needed at the moment. Apparently someone bought the last one since then and they are no longer available. Might find one on ebay, but I'm not sure I'm going to do that. For long distance travel, that flat nav screen makes a pretty good place to stick a Nuvi. Yeah, I know.........
I always travel with a Nuvi as backup anyway.
Old Jan 6, 2022 | 08:14 PM
  #43
Nautivan's Avatar
Thanks for the Cinturato recommendation. Not sure what I’m going to do. My brother has an extra set of wheels from an x308 Xjr (18” I think? Not sure if bolt offset is the same). Anyway tires won’t solve my mechanics recommendation not to drive the car on salty northeast winter roads though…. One thing at a time, need to resolve the leaky valve block first.
Old Jan 6, 2022 | 08:39 PM
  #44
Sentinelist's Avatar
Thanks for sharing the images, Nautivan- saved for reference.
Originally Posted by ChrisMills
Just guessing here, but leaks in the valve block (ie the valves) may be "suspected rare" but why is that? The valves are the only "moving part" FFS (aside from the compressor).
I have no idea why people preferentially change this or that shock because this or that one goes down. The air bladders don't leak with use unless damaged (I opine!). OTOH the valves, they open and re-seal every time an adjustment is needed. Valves...opening and closing holding air...would also explain why sometimes my suspension has a very slow leak and sometimes (like currently) it is perfect. The shocks didn't change, the valves re-sealed!
I also note that "everyone" who went to coil-overs, did so because they changed shocks with no result and couldn't find the problem. I don't understand why so few suspect the valve block.
/end guess/
P.S. A leak of an internal valve in the valve block, would exhaust through the compressor arrangement wouldn't it?
Fair statement- I didn't know about the block before I made my decision and went with the coilovers. Adding to my notes to check for when I one day 'spring' (aha) for the Bilstein B4s.
Old Jan 6, 2022 | 08:44 PM
  #45
Originally Posted by Jacuar
It is true that valves in a manifold will fail on occasion, but airs springs are a wear item with a service life that require routine replacement. This is because the rubber hardens with age and is prone to dry rot, which leads to cracking and splitting. I believe this is why Arnott offers lifetime replacement for their air struts (with a professional service requirement, I think).
It can be very difficult to isolate a fault or leak in the system. The air lines crack, o-rings degrade, height sensors are electromechanical and have issues, compressors have several possible failure points, and so on. Sometimes people lose patience after prolonged efforts and costs in troubleshooting this problem and exchange this exceptional dynamic system for a more reliable static suspension. In fact, I have a set of coilovers for my XJ in case I eventually choose reliability over the cool factor. In the past, I have converted several of my Rovers for the sake of reliability.
The other main challenge with air suspensions occurs when temperatures drop below freezing. Rubber loses elasticity as temperature declines (ever freeze a rubber band?) and depending on how the air springs seal to the struts, this can be a real problem. On the older Land Rovers with air springs, below-freezing temps will often cause the air system to discharge all of its pressure leading to a bumpy ride to work or the store on icy or snowy mornings. As the vehicle warms during the commute, the air springs become warmer and their elasticity, and, concomitantly, ride height is restored. More generally, it's very common for a perfectly working air suspension to be problematic at lower temperatures and then return to normal operation and reliability when temperatures rise again. My suggestion is to consider converting to a static suspension if you prefer to drive your Jaguar during sub-freezing conditions. Personally, I would avoid driving mine during these conditions to minimize corrosion potential.
Finally, something to consider:
A combustion engine consists of many moving parts, but which components (excluding fluids and filters) have the shortest service intervals? The rubber ones.
Yep, all of this.
Old Jan 6, 2022 | 08:49 PM
  #46
Good tip- so 2011 works with this system?? In reality I use Maps on my iPhone with Siri doing the turn-by-turn (over my FM Bluetooth modulator), if I'm going somewhere new at least. Rarely use it day to day. But I always leave the factory nav map up with it's blinky position cursor. It'd be cool if that could be mirrored on the rear screens.
Old Jan 6, 2022 | 08:53 PM
  #47
I just put on Continental Control Contact Sports which are all seasons. Worth checking out, but I'm biased. Continentals always go on my cars and BFGs on my trucks.
https://www.discounttire.com/buy-tir...srs%2b/p/89652
Old Jan 6, 2022 | 09:08 PM
  #48
Nautivan's Avatar
I have Conti Extreme Contacts on my Benz roadster and I’m very pleased with them as well….
Old Jan 6, 2022 | 09:13 PM
  #49
That's what I always had on my XKR- they're great too. Particularly if you don't want to pay the cost and treadwear premiums for Michelin Pilot Sports, etc.
Old Feb 7, 2022 | 09:06 PM
  #50
And then, a beautiful set of Sepangs just appeared... at a price one would expect for a beautiful set of Sepangs... I'm going to have to sleep on it. Again. And wouldn't be disappointed if someone here decides to grab them instead. Starting to wish I hadn't just put new tires on my 19s...
https://www.ebay.com/itm/33426181737...kAAOSwayxhwLX8
It was a long sleep... and thankfully none of you grabbed them. Because these are now in my garage.
Time for another sleep on new tires... again. My chrome 5-spokes (with or without 'new' tires) will be up for sale in the Classifieds section shortly- please PM me if you're interested. I've got a couple folks I owe photos to of them this weekend.
I'll close the loop back here once they're sold and I get the Sepangs on with updated pics. Going to re-find a thread I saw on compatible 20" tire sizes next to think about widening the sidewall out on these for protection. Possibly spacers, TBD.
Old Feb 8, 2022 | 01:14 PM
  #51
Wingrider's Avatar
They do look nice
Old Feb 8, 2022 | 01:44 PM
  #52
Nautivan's Avatar
Indeed they do look good. Might take some effort to keep them detailed?
Did you see the 2006 portfolio sell on Bringatrailer last week? …. Wow
Old Feb 9, 2022 | 12:23 AM
  #53
Originally Posted by Nautivan;[url=tel:2494543
2494543[/url]]Indeed they do look good. Might take some effort to keep them detailed?
Thanks and probably will but worth it since it won’t be daily driven! Should stay cleaner longer.
Yeah that was wild! Top dollar for top spec.
Old Feb 15, 2022 | 11:56 PM
  #54
It is complete. Probably.
Old Feb 15, 2022 | 11:59 PM
  #55
TommyBoah's Avatar
That is one gorgeous cat!
Old Feb 16, 2022 | 09:31 AM
  #56
Nautivan's Avatar
Awesome!
Old Feb 16, 2022 | 06:05 PM
  #57
Nautivan's Avatar
Default Satin sepangs
The more I look at them the more I like them. I didn’t realize at first glance that they had the satin finish. Elegant with a hint of steam punk. They look great
EnigmaX100R
Mar 23, 2020 03:27 AM
yankees25
XF (X260)
16
Dec 21, 2019 11:55 AM
Truck Graphics
Jul 16, 2018 05:33 PM
Frog
Sep 16, 2013 11:14 PM
david i
Jun 11, 2012 11:53 PM
