Non-Navigation X350 Radio Display Screen Flickering
Old Aug 6, 2012 | 10:40 PM
Seth's Avatar
Question Non-Navigation X350 Radio Display Screen Flickering
Hi
I have a non Navigation touch screen XJR with 2 small screens, one for aircon and another one below for the radio.
The radio screen flickers and would go off and come on randomly as if there is a loose wire connection. What is causing the flickering and how do I solve it?
Thank you,
Old Aug 9, 2012 | 05:46 AM
ryejag's Avatar
could not easily resolve the same issue on my 2004 XJR and just purchased another radio on ebay. The radios are not that costly, but you do have to take out the center console to get to the radio.
Old Aug 11, 2012 | 09:01 PM
ryejag's Avatar
Default salvage radio code???
I have purchased a salvage yard rado to replace my original radio which works but the screen will not display channels and other details. Not sure what radio code will be required? I have the code for my factory radio, but not sure if that will work on the salvage yard unit??
thanks
Old Aug 12, 2012 | 10:10 AM
Seth's Avatar
Maybe try to get the salvage vehicle's VIN and approach your dealershop service department for a system reset.
Old Aug 13, 2012 | 09:19 AM
Flstfi's Avatar
ryejag. You may also call Jaguar direct and explain your situation and give them the VIN off the salvage car and they should be able to tell you the code.
Majik Lasers
Aug 2, 2024 01:49 AM
Forcedair1
Feb 19, 2020 01:51 PM
thechaosmachine
Sep 23, 2015 10:03 PM
drewlabarbera
Sep 14, 2015 07:46 PM
tberg
Sep 7, 2015 07:32 AM
