not starting
Old Jun 16, 2021 | 08:00 AM
Vitochops's Avatar
Unhappy not starting
HI! May be it was already here, Jaguar XJ 6 1997, 3.2, not starting, turning key, lights on the dash coming on, but nothing happened after, engine not starting, even not trying to start, what can it be?
Old Jun 16, 2021 | 10:39 PM
ChrisMills's Avatar
Wrong car forum, you have either an X300 or X308.
Anyway, a trick which AA uses, is to hit the starter motor with a stick.
It's not Voodoo, The theory is that the starter brushes might be worn, and a bit of vibration might cause them to make contact.
If it was a low battery, I guess you'd see some dimming. You do have a charged battery, right?
Old Jun 17, 2021 | 03:34 AM
Vitochops's Avatar
Thanks for the answer, yes, its x300,x330. Its new battery on it, will check starter and wires first
Brian F Rideout
Dec 1, 2017 02:52 PM
Nicholas Coffey
Nov 17, 2016 04:24 PM
geberhardt
Sep 24, 2014 01:10 PM
2003 S-Type
Jul 10, 2012 08:41 AM
