OBDII Freezes up 04 XJ8
Old Mar 24, 2020 | 05:45 PM
Hyrum Lindquist's Avatar
Default OBDII Freezes up 04 XJ8
I have a bluetooth BAFX Products sensor and when i plug it into my 04 XJ8 it throws out every error and warning on the dash and prevents me from starting the engine when turning the key. Once i remove the OBD the car goes back to normal. I got codes of P1638 and P1642.
Has anyone else had this and know how to resolve it?
Old Mar 25, 2020 | 01:13 PM
JagV8's Avatar
Either it or the software sounds faulty. Not rare with clone devices, sadly.
Old Mar 25, 2020 | 07:49 PM
The OBD scanner i have works perfectly fine on my hyundai and my nissan. its just this jag that i got that acts up weird and prevents the car from starting
Old Mar 25, 2020 | 08:44 PM
Wingrider's Avatar
The icarsoft i930 is an inexpensive Jaguar specific reader.
There are many more expensive ones but for the money, it was the best i could find.
It reads & clears many codes ordinary readers do not.
It is a necessary expense with a lot of, if not all cars anymore
Old Mar 26, 2020 | 02:27 AM
JagV8's Avatar
They use different protocols to talk to different things so whether it works on another car means nothing useful sadly.
Old Mar 27, 2020 | 11:44 AM
JCalhoun's Avatar
I feel like you are trying to reason with a 2 year old who is having a tantrum. If she doesn't like your code reader then stop using it and get one she likes.
Good Luck
Jeff
Old Jul 6, 2020 | 08:36 AM
Mark Saggese's Avatar
I ran in the same issue with BAFX product. When I emailed their customer support that thought it might be a short in my OBD port. I did inform them I am able to use an Autel OBD meter with no issues. They sent me out a second one with same result. It does not appear that the BAFX work with the 04 jaguars XJ*. I have seen other people use this product with success on newer Jaguars.
Old Jul 6, 2020 | 08:49 AM
Blairware's Avatar
FYI: Jaguar made a modification in late 2005 for the 06 model year:
"The software platform of the cars changed from having a VID Block, to having a CCF (Car Configuration File) same as the Land Rovers, and later Jaguar models. The software format of the major modules changed from using .bin files to .vbf files.
I have no idea if this affects the function of OBDII, I assume not, but it could explain why scanners have more issues with the earlier cars. As another post said: If it hurts when you do THIS, don't do THIS.
Old Jul 6, 2020 | 09:47 AM
JagV8's Avatar
It has nothing at all to do with it. Completely irrelevant.
