Oil light issue
Old Jul 31, 2021 | 07:05 PM
Richardhw's Avatar
Default Oil light issue
My car is a 3.0 V6 and the issue is that the oil warning light is coming on while the vehicle is at idle, it started last week a couple of times, it goes off as soon as the engine revs above tick over but now it is coming on every time the car is not under load.
Are there any known causes of this ? could it be the sender unit ?I believe there are 2 for the oil but I am not sure and I am not at all familiar with these engines.
The oil level is ok, if anything possibly a bit high, the thought of it being the oil pump does concern me a bit.
Old Jul 31, 2021 | 11:47 PM
Panelhead's Avatar
Default Measure it,.
If engine temperature related this could be main bearings. Usually they give up slowly. If problem gets worse fast it could be pump failing.
If may be worthwhile to change the sending unit. Not likely the issue, but not a bad job. Oil pump should be okay job. Mains are major.
Every car I have owned with oil pressure light coming on needed main bearings. Maybe your luck is better than mine.
Old Aug 1, 2021 | 02:09 AM
Richardhw's Avatar
Cheers, I will take note of the temperature but I think it does the same from cold so hopefully not the mains.
Old Aug 1, 2021 | 01:19 PM
Panelhead's Avatar
I looked up the pressure gauge, sending unit. The were reasonable at 7 -11 USD at Rockauto for the 3.0 V6.
Old Aug 1, 2021 | 04:07 PM
Richardhw's Avatar
Thanks, they are a bit more on my side of the pond although they are not expensive but its going to be the first thing anyway.
jmarkitell
Mar 12, 2016 04:59 AM
petemohr
General Tech Help
Jan 2, 2015 08:38 PM
doctordeuce
Dec 12, 2014 10:07 PM
tibam13
Sep 19, 2014 11:27 PM
kench
May 31, 2013 07:59 AM
