Please Help with 04 Jaguar VDP XJ8 electrical problem ?
OK this is my first post here and I hope somebody can help me .
I have 04 VDP X350 41k miles with navigation . Problem I'm having is that car after it sits for 5-10 min will not run for long only 2-3 sec . I can here pump priming but after car starts it shuts off. Together with this my windows are not working fuel gage not working headlights not working and air . On the screen I'm getting message ignition off ac not available . After I leave key in ON position for 10min to 30min everything comes back on and I can start the car ,windows, air, headlights everything works as it should for as long as I keep car on as soon as I turn it off for 5-10min problem comes back . I need to know what controls all this together and if somebody can tell me where to look for a solution . There is no codes or bad fuses . Please Help
The circuits you describe that are not working are all switched on from the ignition switch, so I would start from there. A clue is given by your central screen display - "ignition off"
Here is your wiring diagram:
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Sometimes the wiring colors are wrong; like the wires to the AC/Heater fan.
How abouth fuse boxe or front and rear electronic module why it comes on after some time and it stays on . One night before all this star happening my dother open all windows and suroof with remote and I got some water in the car
One thing that you will see in the wiring diagram is that electrical components work "backwards" from what people expect. Due to the use of power transistors, most stuff is "hot" (pos) all the time and the ground is switched on and off. It is possible that water got in somewhere and is messing with switching. Don't get side-tracked by the transport relay just after the battery. It isn't your problem.
hafren
Aug 30, 2023 03:42 PM
Paradigm
Jun 15, 2019 05:59 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
Jaguar Forums Editor
Jaguar Press release
Aug 26, 2015 05:08 PM
