Please tell me what these 3 parts are called
Old Aug 4, 2021 | 01:17 PM
  #41
xalty's Avatar
Originally Posted by the brain
ahh right, just upper are cross-compatible? Thanks
lower is too but tell the mechanic you need to put a washer on each side to make up for the extra space on the hub. this is if your car has the earlier wishbone with 59mm hub side bushing, 2004 is a grey area
Old Aug 5, 2021 | 01:01 PM
  #42
the brain's Avatar
So far I'm about to order these from a 2011 XF Sedan with only 30k on the clock...what do you think, look ok? only 35 euro each
left
right
Old Aug 5, 2021 | 01:13 PM
  #43
xalty's Avatar
looks good to me
Old Aug 5, 2021 | 02:36 PM
  #44
the brain's Avatar
looks good to me
better than mine anyway!
Old Aug 11, 2021 | 03:42 AM
  #45
the brain's Avatar
Hi, does anyone know the cheapest way to replace the air shocks with coil shocks? saw a kit for 320 euro but was wondering if any non air shocks off other models may fit so I can buy off a scrapper, thanks!
Old Aug 11, 2021 | 09:25 AM
  #46
xalty's Avatar
buy all 4 shocks from an XF
mechanic will have to enlarge the holes towards the center
Old Aug 12, 2021 | 08:21 AM
  #47
the brain's Avatar
thank you for your insight
so far ive bought the front shocks with springs from a 2015 Jaguar Xf 2.7 V6 Diesel 36 euro each
Old Aug 13, 2021 | 07:13 PM
  #48
the brain's Avatar
I see what you mean by enlarging the holes towards the center. Have you done this? Do you know if the car sits higher or lower after changing all the shocks for these?
Old Aug 13, 2021 | 07:32 PM
  #49
xalty's Avatar
yes with springs from a 3.0 V6 s-type. it sits pretty much the same as before
i don’t know how it’ll sit with the diesel front springs
Old Oct 5, 2021 | 11:32 AM
  #50
the brain's Avatar
sits perfectly! done! front and rear. thanks for your advice!
Old Oct 5, 2021 | 11:40 AM
  #51
the brain's Avatar
now to figure out how to get rid of the error messages before my next annual technical test. i took the relay out so the compressor won't flatten the battery, but maybe just unplug the compressor, ive read something about returning the correct voltage back to the controller etc,
but it drives great.
Old Oct 5, 2021 | 11:50 AM
  #52
xalty's Avatar
unplug fuse 52 and fuse 12 in rear trunk fuse box. they will be 10A and a 20A
disconnect battery, touch terminals together for 20 seconds.
reconnect and messages will be gone.
Aidan2001
Sep 27, 2020 06:15 PM
Aidan2001
Sep 25, 2020 10:33 PM
E-Type Erik
E type ( XK-E )
Aug 6, 2020 03:47 PM
micmee1
General Tech Help
Feb 8, 2020 07:17 PM
