pressurize shocks for leak test?
Old Feb 19, 2013 | 03:56 AM
Roman K's Avatar
Default pressurize shocks for leak test?
Hi all, my rear has dropped
I need to do a leak test with soapy water but can't jack the car sins its way to low. Is it possible to pressurize the system to raise the car?
Old Feb 19, 2013 | 06:41 AM
Jag XJ8 Red's Avatar
Banned
Maybe. Depends on why it is too low. Will the compressor run? If so, you can jump the relay to fill the tank. Then jump the solenoid block.
Old Feb 21, 2013 | 03:36 PM
Roman K's Avatar
Brilliant
How is this done?
Front shocks work normally, only the rear has dropped.
Old Mar 15, 2013 | 03:04 AM
Roman K's Avatar
bump
Enyone please?
I have been driving like this for a month now. the front is still in normal hight but the rear is way to low.
How can I jump the relay to fill the tank?
My guess is that the compressor is broken and I probably have a leak in one of the rear shocks. But I need to confirm before I start spending the money on parts
dsnyder586
Dec 29, 2024 07:39 PM
OkieTim
Sep 8, 2015 04:48 PM
EZDriver
Sep 8, 2015 09:25 AM
Busa R
Sep 3, 2015 05:01 PM
OkieTim
Sep 2, 2015 12:48 PM
