Rear Control Arm Removal
Old Feb 5, 2022 | 02:41 PM
cooldood's Avatar
Default Rear Control Arm Removal
Apologies if this has been answered elsewhere, but I just spent an hour looking and cannot find the answer.
I am trying to remove the right lower rear control arm and struggling with the rear inner bolt (so the bolt that goes through the inner bush at the rear of the wishbone).
Is that a captive nut, locked in place, or should it spin? - Answered this one myself, yes there is, it has a plate/finger welded to it, so turn only the bolt.
And why remove the brake caliper? - Answered this one myself, bottom outer bolt fouls on caliper,
Old Feb 5, 2022 | 04:08 PM
scooterforever's Avatar
So... you're about to get a surprise when you try to remove the front inner bolt of that control arm: if it's like mine, the bolt will get trapped against the sheet metal when you try to take it out. Rest assured, it *will* come out, but you might have to use a rubber mallet to assist it. There is enough room for the control arm change procedure, but I suspect the control arms were assembled in the factory with the subframe separate which gives a whole lot more room to work with.
Old Feb 5, 2022 | 06:07 PM
cooldood's Avatar
The job actually was not too bad, the self locking nut on the rear inner was surprising, and the bolt felt so tight/ready to snap. So different turning the whole bolt compared to just unscrewing a nut.
The front inner bolt was not too bad, I had to pull the plastic wheel arch liner towards the the outside of the car a few inches, but the bolt was not hampered by the sheet metal.
Main hassle was moving the brake caliper, then winding back the piston to get it all back on the disc (push and turn clockwise - the special tools are a huge help there).
Everything else was routine, including the cramped spaces and difficulty of accessing things :-)
FYI Car has springs/shocks not air struts.
Will do the left hand side in a couple of weeks, upper, lower and tie rod (new sway bar link already on).
Old Feb 6, 2022 | 09:22 AM
Wingrider's Avatar
Worked till almost three AM doing both sides.
The uppers & lowers on one of mine.
Not a good time, glad that i had help.
Old Feb 8, 2022 | 12:06 PM
cooldood's Avatar
Update, my bad, brake pads were not mounted correctly and binding.
So, coincidence or not?
Now there is a deep humming noise evident from the back at freeway speeds.
Seems to be more from the left, the side I have not done yet.
Sounds more like a driveshaft or maybe bearing issue?
Not had a chance to look at it yet, I will get the rear up on axle stands at lunchtime, look for damage, free play and maybe run it in gear and look for wobbling wheels and bearing noise.
Will plow ahead with changing control arms, then get wheel alignment and balance done.
Old Feb 8, 2022 | 01:24 PM
Panelhead's Avatar
Default Brand of arms?
Which brand did you settle of for the replacements?
Old Feb 8, 2022 | 03:31 PM
cooldood's Avatar
Lower arms are the Moog units.
Not sure on the rest, a kit from eBay.
Old Feb 8, 2022 | 05:27 PM
Wingrider's Avatar
Seems almost all except the stock ones.
Are made by the same third party Chinese manufacturer
Edwardpantani
Apr 12, 2020 06:45 AM
beulahjag
May 16, 2018 11:04 AM
iownme
Nov 19, 2015 02:27 PM
zak
Oct 13, 2015 11:46 AM
satwarez
Jan 12, 2011 01:33 PM
