Rear differential leaking
Old Dec 22, 2021 | 06:03 PM
SJ9809's Avatar
Default Rear differential leaking
Hi,
On my 2006 XJ8l the rear differential is leaking, it’s not enough to drop the the floor but I have to address it sooner or later.
From what I see it’s only on passenger side, so I guess it is just the axles seal. How difficult is the work. Drop the axle or is it possible to just pull out the CV axles and replace the seal.
Any advise is highly appreciated!?
what fluid should I use for refill and how much?
Old Dec 22, 2021 | 11:32 PM
xalty's Avatar
yes you can even detach the CVs with the knuckle some put up a fight some will just pull out.
seal is XR821244/National 71085
use motorcraft 75w140 or equivalent
Captain Bob 369
Oct 6, 2021 02:09 AM
sambella
Oct 1, 2014 03:02 PM
David N. Warner
Mar 30, 2014 01:00 PM
magicjuan17
May 31, 2013 10:33 AM
DaveC
Jan 9, 2013 03:17 PM
