rear turn signal
Old Jan 20, 2017 | 11:05 PM
rodney williams's Avatar
Default rear turn signal
my rt rear turn signal sometimes stop working and makes the lt brake light blink.
Old Jan 20, 2017 | 11:06 PM
sorry its a 04 xjr
Old Jan 21, 2017 | 03:33 AM
clifton94's Avatar
Possible bad earth
Old Jan 22, 2017 | 04:42 AM
roviw's Avatar
As mentioned above, when other lamps blink at the same time it is generally an earthing issue, pop the rear cover off inside the boot ( trunk ) and see if there is anything obviously corroded, may be possible to undo a nut and clean it up and refit it.
Old Jan 22, 2017 | 05:44 AM
Partick the Cat's Avatar
Ah, it's not quite that simple because the brake lights and the turn indicators are switched in their earth return wires by the Rear Electronic Module. You should check the earths (multiple) from the REM to it's earth/ground points on G24. That is in the boot on the RHS furthest forward (probably behind the RH boot liner).
