Rear Wheel bearings - same as front?
Old Feb 21, 2014 | 09:03 AM
hunter34's Avatar
Default Rear Wheel bearings - same as front?
I replaced the two front wheel bearings using this
Robot Check Robot Check
wheel bearing, which is a Timken HA590224.
Are the rear wheel bearings the same part number as the front bearings? If not, what is the Timken part number?
Thanks!
Mark
2004 XJR
Old Feb 22, 2014 | 05:02 AM
jaglover922's Avatar
They are no the same, fronts are hub and bearing units, rears are press-in bearings, you would need a press or bearing tools to remove the rears. Not sure about part numbers. I only use Jaguar dealer parts.
Old Feb 22, 2014 | 05:26 AM
Unfortunately the Parts Catalogue isn't much help in this case as Jaguar do not list the front bearing as a separate item:
I can at least give you the Jaguar part number (XR81723) for the Rear Hub bearing which may help identify an alternative source:
British Parts UK list it:
Wheel Bearing Rear - XR81723 | Jaguar S Type, Jaguar XJ - X350 - XJR | Jaguar | British Parts UK
The US division of British Parts is a possible source for you.
prettydaim
Mar 28, 2021 07:47 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
