Regular gas?
Old Oct 22, 2011 | 11:26 AM
  #41
steve11's Avatar
ud
Originally Posted by Glendoramike
If your ride has computer controls, then the computer makes adjustments to make up for this. With variable cam timing, the intake valve closing is retarded to make your dynamic compression ratio drop down to around 8 to 1.
Knock can also come from pre-ignition which isn't controled by the spark timing.
Remember, your computer will be trying to advance the cam timing for more low end power and then the knock sensors will cause it to retard the timing. This will go back and forth and it isn't so swell for the motor.
NOPE. Very imaginative, but knock sensors don't work this way.
Old Oct 22, 2011 | 11:43 AM
  #42
Mikey's Avatar
Pre-ignition cannot be eliminated by increasing octane levels either.
Old Oct 22, 2011 | 04:32 PM
  #43
Glendoramike's Avatar
I didn't put down the whole process of how a ECU deals with knocking and everything else.
The point is that with variable cam timing; at low rpms the cam is advanced to give high torque. Of course this raises the dynamic compression ratio and low octane gas can knock. Small block engines have less pre-ignition problems than big blocks. Generally, a small block can run on regular if the compression test reads around 160 psi. When you get up to around 180 psi, then premium is needed.
When the knock sensors pick up knocking the ECU has instructions on how to stop it. Retarding cam timing to drop the dynamic compression ratio works, but cuts the low end torque. There are other things that can be done like adjusting spark timing, or feeding in exhaust gas.
Old Oct 22, 2011 | 09:27 PM
  #44
Mikey's Avatar
Not to be rude, but twice you've used the term 'pre-ignition' in place of 'detonation'. The two are very different and essentially unrelated phenomena and the terms are not interchangeable. Variable valve timing, altering ignition advance or inducing exhaust gas recirculation may be effective in dealing with detonation, but not with pre-ignition.
Old Oct 23, 2011 | 08:06 AM
  #45
steve11's Avatar
ud
Still Nope, but a tiny, tiny bit closer to reality. Two correct phrases above are:
"the ECU has instructions"
"There are other things that can be done"
The rest is either partially or completely incorrect.
aode06
Jul 28, 2023 02:26 PM
hkmcmast
Nov 29, 2015 06:56 AM
workworkwork
Oct 23, 2015 10:26 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
