Replaced throttle body coolant hose, but still wants to overheat
Old Apr 18, 2023 | 01:10 AM
dfatherree's Avatar
Default Replaced throttle body coolant hose, but still wants to overheat
Over the weekend I pulled the intake manifold and replaced the throttle body cooling hose, which had split.
After reassembling the car, including replacing all that brittle vacuum tubing, I thought everything was good. No leaks, no error codes, running smooth.
Then the temperature started to creep up. I shut the car down, hearing the electric fan continue to run.
After it cooled down a bit, I started it back up. A few minutes later, the fan kicked on again. The temperature started rising again, so I shut it down.
I'm about to pull the thermostat housing and check it, then I guess the water pump. Any other ideas?
Cheers,
Dwayne
Old Apr 18, 2023 | 05:30 AM
Wingrider's Avatar
Thats a move in the right direction.
While things are apart.
Spend some time looking things over
Looking for things that might need replaced soon.
Trying to avoid, taking apart what you just fixed.
Old Apr 18, 2023 | 07:42 AM
xalty's Avatar
failure to bleed
try again and if you still can’t do it get an airlift and it will work guaranteed
Old Apr 18, 2023 | 03:29 PM
dfatherree's Avatar
You guys rock!
Thanks Xalty, I did the bleed and she runs like a f***ing top!
Cheers,
Dwayne
achysklic
29
Feb 25, 2025 08:36 PM
John in Tennessee
Apr 11, 2022 10:21 PM
JaguarXK'10
Oct 25, 2020 03:31 PM
kenc
Aug 23, 2020 05:33 PM
vdpnyc
Sep 26, 2014 09:10 AM
