Rim height problem
Old Sep 2, 2021 | 05:55 PM
Eric8's Avatar
Default Rim height problem
Hello!
today, i have buy a set of wheels in 19" but i do not know the dimensions required for my car
these are in 245/40/19 into the front and.. 275/35/19 for the rear..
naturally now i have a pressure tires trouble because the wheels are not in the good height..
My question is, is that possible to set the problem with JLR or switch off the sensor?
Thank you !
Old Sep 2, 2021 | 06:18 PM
Eric8's Avatar
well I suppose, it is the height which is problematic, someone can help me please!
Old Sep 3, 2021 | 01:50 AM
quattrofrank's Avatar
Do you have tire pressure warnings?
Did your new rims include tmps sensors?
Old Sep 3, 2021 | 09:00 AM
wfooshee's Avatar
Obviously English is not your native language, so a little clarification, please. Are you saying you get a height warning, or are you saying you're getting warnings from the tire pressure monitoring system? I'm asking because you said "i have a pressure tires trouble because the wheels are not in the good height.." which doesn't make sense. Tire pressure has nothing to do with height, so I don't understand if you're getting a pressure warning or a height warning.
Old Sep 3, 2021 | 09:09 AM
I think the confusion is probably because on some cars the abs sensors is used for pressure monitoring and then different tyre dimensions can cause troubles.
On the jaguar x350 the system is based on sensors inside the wheels so mixing of rolling circumferences is not an issue
Old Sep 3, 2021 | 03:55 PM
wfooshee's Avatar
OK, so he's thinking that changing the diameter of the wheel has messed with the pressure monitoring, when actually the issue is that the wheels don't have the sensors the car expects to see.
I kept thinking "ride height" when he said "height," and it made no sense.
Smokin
Mar 30, 2025 03:15 PM
Kuddlesworth
Aug 5, 2021 10:09 AM
slownlo
Jun 9, 2017 11:03 PM
Lalub
Jul 13, 2012 08:44 PM
hifipm
May 8, 2012 09:00 AM
