Rusty side marker connectors and bulb connectors....on 04/ xj's
Old Apr 3, 2010 | 11:35 PM
cincinnati's Avatar
Default Rusty side marker connectors and bulb connectors....on 04/ xj's
Are there anyother 2004 XJR/XJ owners that have rusting side marker connectors ? The dealer says that you have to replace the whole marker and connector. $78.00 Any other ideals or remedies?
Old Apr 4, 2010 | 08:41 AM
MTW's Avatar
MTW
cincinati.
I just replaced the side marking light in the front bumber - price $45 each(Jag dealer) - I replaced it because it was cracked. Try to sand the connector and use a electronic deoxidizing spray(fry's) and add dielectric grease to prevent it from rusting in the future - it should work.
MTW
Old Apr 4, 2010 | 03:36 PM
310jag's Avatar
I've had this problem with my right rear bumper marker. I took the light out, ran a small bead of silicone around the circumference of the light where the lens meets the rest of the housing to hopefully seal it up. As for the corroded socket, I ended up cutting the crusty plug off factory harness and solder on a new (old) one from a salvaged car.
I never had this problem with the lights on my Xtype which seemed to be constructed in a very similar manner.
Old Apr 4, 2010 | 07:08 PM
Jag400's Avatar
2005 XJR I got a front Marker for 40 bucks 20% discount off parts and replaced it with the driver side rear marker and saved the yellow lens. Trust me there's no way around it. I tried the spray and it did not work to much rust. Stay away from auto car wash only wash your car by hand
Old Apr 5, 2010 | 06:05 AM
cincinnati's Avatar
Thumbs up
Good info gentalmen. Im gunna try and find a cheap replacement of sorts.
Old Apr 8, 2010 | 02:55 PM
cincinnati's Avatar
bump up
afterburner1
Dec 16, 2015 12:12 AM
billbjork
Sep 10, 2015 07:41 AM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
