SDD question
Old Nov 25, 2015 | 02:38 PM
fingers's Avatar
Default SDD question
hello all
just slowly getting to grips with the ids sdd v131 software, the first thing i wanted to do was turn the damn daylight running lights off wich were enabled from new at the request of the original owner,
quite easy to find ,
service functions
then select .complete vehicle-dealer options from the screen
and a whole bunch of stuff comes up of what is enabled or unabled with the option of choosing to turn things on or off,
here`s my problem, the dlr are enabled so i select to disable them and then click on the green tick in bottom right corner and a caption comes up saying i have chose to change nothing , i have clicked on a few other things to see if i can turn them on or off and nothing happens,any tips or ideas.
many thanks
rob
Old Nov 26, 2015 | 02:51 AM
dsetter's Avatar
Originally Posted by fingers
hello all
service functions
many thanks
rob
Be sure to check that you have selected the disable, and checked the selection before selecting the green check. It seems like cac redundant selection, but you have to confirm the selection before proceeding.
Old Nov 27, 2015 | 02:35 AM
fingers's Avatar
Thanks for advice,
Managed to set drl to disable but they are still on.
Managed to set door mirrors to dip when in reverse and to disable drive away locking.
I've noticed that there is an option to switch from Canadian drl to Scandinavian drl but no option to have neither, I'm thinking that disabling drl all together overrides either of them options, anyhow they are still on and I've noticed my front and rear fogs don't work either no lights in and no dash light for them, and to top it off I've not got permanent high beam except when I flash.
Ran dti and no fault comes up.
What a mess ????
Old Jan 14, 2016 | 12:33 PM
Lagonia's Avatar
Have you had success in resolving these problems?
C.A
Dec 20, 2015 04:04 AM
Larry-Cleveland
Dec 8, 2015 04:41 PM
fingers
General Tech Help
Nov 23, 2015 02:23 PM
fingers
General Tech Help
Nov 21, 2015 05:31 PM
fingers
General Tech Help
Nov 21, 2015 09:43 AM
