Seat Belt retractor
Old Nov 26, 2012 | 10:21 AM
gmcgann's Avatar
Default Seat Belt retractor
I did a search but didn't find anything on this. The driver's seat belt in my '04 XJR doesn't retract well, a common problem I have had on many cars. I guess the springs get weak, but when I take the belt off I have to almost feed it back into the spool to get it to retract. If I don't I end up with the belt hanging out the door or slamming the door on the buckle. If I toss the belt back in the car it will sometimes slowly retract on its own, but other times I get back in and find I'm sitting on the belt. Does anyone know of a fix for this short of replacing the retractor assembly? Is there an easy/cheap fix? Thanks.
Old Nov 26, 2012 | 10:44 AM
esloser's Avatar
Mine does the same on a 2004 xj8. Although, it retracts a bit faster than what you describe. Would be interested in hearing a fix for this.
Old Nov 26, 2012 | 02:46 PM
meirion1's Avatar
That's a real nuisance.
I don't think you can get into the reel because of safety reasons.
They are available used.
Old Nov 26, 2012 | 10:18 PM
H20boy's Avatar
Try pulling it all the way out first, make sure it isn't flipped/folded closer to the reel...see if that helps it retract too. Exercise, not just for humans.
bdboyle
Sep 16, 2019 05:58 PM
magmedia
Aug 15, 2019 08:54 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
DFW
Oct 1, 2015 07:22 PM
BlacXJRcat
Sep 25, 2015 06:43 PM
