Seat height adjustment issue.
Old Mar 20, 2011 | 12:50 PM
45Wheelgun's Avatar
Default Seat height adjustment issue.
Well this all worked fine until yesterday.
The passenger seat will no longer raise or lower the rear portion of the seat bottom. The motor starts, and the seat lifts a very small amount and then stops. It will then lower that same small amount. The front part of the seat works fine. All of the rest of the seat adjustments work correctly.
This happened while I was doing a deep cleaning of the interior of the car and the seat was as low as it can go, and as far back as it could go. I wonder if I set it passed it's range somehow.
I am hoping there is something jammed, stopping the seat from going up, but I don't know where to start looking.
Any ideas?
Old Mar 21, 2011 | 12:52 PM
45Wheelgun's Avatar
Anyone?
Thought maybe one of our JagTechs might be able to help...
Old Jul 3, 2011 | 07:53 PM
mattrains's Avatar
45wheelgun,
Did you ever fix the problem? I'm having the same problem as you except its my drivers seat that won't raise its rear portion.
Thanks for your help,
Mathew
Old Jul 4, 2011 | 12:34 PM
45Wheelgun's Avatar
I got mine fixed, but not without a trip to the dealership.
All they did to fix it was to lubricate the screw/track that the motor operates. Once it was past the binding point it ran fine. The lub they used stunk up the car for two weeks.
So find the motor under the seat, lub the drive screw with some silicon lube seemed to be the answer. I have not had the problem again, but I am also careful not to let it run to the end of it's travel.
scooternva
19
Oct 27, 2015 02:14 PM
Samheath100
Sep 17, 2015 10:03 AM
diablomkii
Sep 14, 2015 02:37 PM
jagent
Sep 12, 2015 09:10 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
