Spark plug wires
Old Jul 4, 2024 | 01:47 PM
Sampjag's Avatar
Default Spark plug wires
Jag 2004 XJR
IT seems no after market auto parts companies sell sparkling wires for this car. Jag dealer( a friend actually) wants $140 per cable … for cryin out loud this is a f’g ford Lincoln engine 😳. Anyone have a Bosch or whatever cross ref spark plug wire part number high quality tight mm ??? Thank you
happy 4th !🇺🇸🇺🇸🇺🇸🇺🇸
Old Jul 4, 2024 | 02:49 PM
Thomas-S.'s Avatar
The car does not have spark plug wires in the classic sense. It has 8 ignition coils, one per cylinder, that incorporate the connector to the spark plug.
The wiring to the ignition coils is part of the engine harness.
Most probably the price the Jag dealer mentioned is for an ignition coil.
Best regards,
Thomas
Old Jul 6, 2024 | 06:11 PM
Sampjag's Avatar
Default thank you Thomas
Thank you Thomas ah duh I should've known that, replaced Coils and plugs just trying to get back to 23 MPG in single digits, had injector system flushed or what ver they do...seemed to have worked. Did have a throttle body code though; maybe connected to dirty injectors ?
BTW is there aw ay to reset computer ; I replced the Arnott air shocks, now they raise and lower normal but still get the message in dash ?
Best regards,
Thomas
Old Jul 7, 2024 | 06:09 AM
clubairth1's Avatar
Community Influencer
Also again and again it's NOT a Ford/Lincoln engine!
Why are you replacing the coils? Do you have any codes?
Old Jul 7, 2024 | 06:53 AM
Thermite's Avatar
Aye.
More's the pity.
Not fair to lay ALL the blame on Jaguar, even so.
Ford controlled the budget at the time they were struggling to get something usable running, allocated far too little money to have had a chance of getting a factory built AND get a new engine design sorted.
Tata's need to build a whole new factory didn't leave funds enough to correct the design shortcomings, later, either - just add new ones.
Old Jul 7, 2024 | 11:07 AM
Thomas-S.'s Avatar
If they have flushed the system, maybe also the throttle body got flushed, as well. Might be the reason fo not having an error code anymore.
Regarding the Arnotts, I would say the resetting the error message for the suspension will not help in the first place.
If you search the forum, you will see quite a few threads about the Arnott air shocks, and that they do not have CATS. It seems that because of this there is an electronic module that you need in order not to have the error messages anymore. I cannot telll from personla experience because I run the otiginal Bilsteins on my car.
Best regards,
Thomas
fishbait1
Feb 8, 2020 12:54 AM
BradsCat
May 21, 2017 11:25 PM
Steve W
Mar 28, 2017 12:04 PM
calvindoesntknow
Jan 18, 2014 03:07 PM
TN8Shooter
Oct 20, 2010 09:13 PM
