Stranded
Old Jul 30, 2009 | 09:55 PM
poboyblues's Avatar
Engine system failure can mean a host of things gone wrong. The puddling on the passenger side is probably caused by your a/c heater matrix box drains being clogged. In my experience, this would not cause the engine systems failure. My first thought is it's throttle related since it's somewhat common. You're going to have to have it towed, if you try to start it again and the warning remains. The warning can go out if the issue is intermittant but will still need diagnosis, because the warning will return. But if the warning is gone, you can drive at your risk.....if it comes back on it will go into limp home and it'll be a slow 600 miles home.
scooternva
19
Oct 27, 2015 02:14 PM
XJPurr
Jan 17, 2013 03:47 PM
LACat
Dec 3, 2012 01:24 PM
