Supercharger duct seals
Old May 30, 2010 | 10:14 AM
djdex's Avatar
Default Supercharger duct seals
Hi folks,
Can anyone tell me the part number for the supercharger duct seals that sit between the supercharger outlet pipe and the charge air coolers, also are they the same part for both banks, I'm gonna do 'em both anyway. Car is an X350 XJR. Thanks.
Old May 30, 2010 | 10:40 AM
BuckMR2's Avatar
Samr part for both banks
AJ86892 from VIN G38320
I think the earlier part number to Vin G38319 which was AJ83972 superceeds to this
Old May 30, 2010 | 02:02 PM
djdex's Avatar
Thanks Buck ! :-)
Old Feb 27, 2011 | 08:27 AM
andrewmccarthy11's Avatar
I've read the instructions on how to change the supercharger oil on the xjr, but I just cannot figure out where the plug is that has to be removed. I've removed the plastic shroud at the front of the engine bay, and I think I can barely see the supercharger now. Where is the plug which must be removed with a 3/16 allen wrench? Do I need to remove anything else to get to it? If you have a picture, that would be great!!
Old Feb 27, 2011 | 10:52 AM
djdex's Avatar
I can't help you there I'm afraid, to replace the duct seals you don't need to touch the charger itself, You only have to go as far as the outlet elbow, and it's an easy job so I didn't bother with pics.
vwbusbits
Oct 13, 2015 03:43 AM
moff1959
Sep 26, 2015 05:35 PM
SD96XJ6L
Sep 25, 2015 10:53 PM
BSM
Sep 25, 2015 05:00 PM
