Supercharger recon/replace
Old Feb 17, 2021 | 01:44 PM
Daniel Macdonald's Avatar
Default Supercharger recon/replace
The rotors on my 2005 v8 XJR are looking a bit tired!
all the Teflon coating on the rotors is flaking off. Can anyone suggest a good place to get the unit reconditioned or should I look at a new/used decent condition unit?
based in UK
thanks in adnanved
Old Feb 17, 2021 | 04:42 PM
Wooford XJR's Avatar
I don't have a source for the supercharger rebuild but I would strongly suggest removing the intercoolers for cleaning while you have everything apart. They will be full of oil residue..
Wooford XJR
Old Feb 17, 2021 | 05:09 PM
jackra_1's Avatar
+1 on the above.
If you can find a low mileage used one with rotors in good shape it would be less expensive.
If you can get a used one replace the rear bearings which is very easy to do and maybe the coupler in the snout if it has too much play.
The rotors on my original SC at 100,000 miles were still fully coated.
I bought a used one and had it rebuilt with smaller pulley etc.
Old Feb 18, 2021 | 02:50 AM
Thanks both for your thoughts, I shall start looking for a secondhand one in good condition!
Here is the current one!...
Old Feb 19, 2021 | 01:23 AM
Hendirk's Avatar
Hold on - are the black spots on the rotors the coating or should they be more like the grayish part?
Old Feb 19, 2021 | 02:23 AM
The black bits are the coating.
Old Feb 19, 2021 | 11:20 AM
jackra_1's Avatar
It is called an ablative coat.
Old Feb 23, 2021 | 09:01 PM
XxSlowpokexX's Avatar
I had the rotor pack rebuilt in my xjr before going with the twin screw. Now it’s back on. Look up super hope performance and talk to Bill Evenoff. He can hook you up with just a rotor redcoat and rebuild or the entire assembly with snout bearings redone.
jackra_1
Mar 14, 2016 07:29 PM
Catsgame
Dec 18, 2014 08:33 AM
WaterDragon
Aug 5, 2013 01:03 PM
princemarko
Mar 21, 2010 12:11 PM
LUXCAR
Oct 29, 2008 12:05 PM
