susp. pump experiences
Old Jun 15, 2017 | 06:11 PM
romroc's Avatar
Default susp. pump experiences
Used eBay pump just installed. Unit came from California, zero rust. NO fault lights once system inflated. Front tends to dip, Arnotts from 2013. Car off road for now. Pain w marker lights terminals corroding, 2 of 4 shot. Vw 1993-1999 fits, not an easy find. Trunk keyless latch bad, trunk wiring looks OK, maybe fuses, or ugh, actuator. Still, overall a nice rig, I like that it's aluminum. Sprayed silicone w teflon around moving parts of windows, it helps.
Old Jun 15, 2017 | 10:38 PM
romroc's Avatar
Addendum/tip: to install the susp. Pump, i first cemented the upper special washers (3) to the support rods. That way, less to become dislodged/misaligned. I had some spray adhesive, and now those washers are set, never need to come down again. Hope this helps.
Old Jun 16, 2017 | 05:00 AM
Muleears's Avatar
Thanks for the tips, romroc.
