suspension coil spring upgrade (need help)
Old May 30, 2022 | 10:06 AM
Basil94's Avatar
Exclamation suspension coil spring upgrade (need help)
Hello everyone,
i'm tired of air struts always going bad so i'm upgrading to coil springs... i searched for arnott coil spring kit one the official website but it seems they don't sell anymore? i don't see a buy option.
anyways if you can please provide links if you can to arnott kit or any other company that makes it as long as the bypass module is included
thx in advance
Old May 30, 2022 | 10:49 AM
hisport's Avatar
https://www.arnottindustries.com/c-2...350-x358-w-ebm
(Give Arnott a call; good folks)
Old May 30, 2022 | 02:37 PM
wfooshee's Avatar
I was going to suggest rockauto.com, where I got mine, but on checking, I don't see then there any more. I do see them on O'Reilly's site, oreillyauto.com, for a good bit more than I paid at rockauto a couple of years ago. (Oops, you're not in the US, though...)
It would still be worth it, to eliminate the ever-constant expense of always fixing the system. Arnott is the only one I know of that includes the device to kill the suspension warning on the dash after installation.
Old May 30, 2022 | 02:56 PM
FreeWifi's Avatar
Originally Posted by Basil94
Hello everyone,
thx in advance
Autohausaz on sale 1269.69
or fcpeuro for 1486.15 (not sure if they price match)
Old May 30, 2022 | 03:27 PM
Panelhead's Avatar
Default Check Rock Auto
The premium version shows in stock for a little under 1200.00 USD.
Old May 31, 2022 | 04:37 AM
EsRay's Avatar
Please put a few details of your car model, year etc in your signature so that Forum Members can give accurate help?
For example, if your Jaguar is 2004 or 2005, then you will not need a bypass module; simply disconnect everything at the Air Suspension Module behind your rear passenger seat!
Old May 31, 2022 | 06:23 AM
Orlando Martinez's Avatar
Default Replacement coils for air suspension
Hello everyone,
thx in advance
check out:
https://www.suncoreindustries.com/pr...del=VANDENPLAS
Old Jun 1, 2022 | 06:34 AM
Petz's Avatar
Gb is crazy right now on those BC-Racing coilovers
very good reviews
Old Jun 1, 2022 | 01:52 PM
pkoko's Avatar
Originally Posted by Orlando Martinez
Are those CATs capable?
Old Jun 2, 2022 | 08:28 AM
wfooshee's Avatar
No. their instructions clearly state that the connector is not needed after the conversion.
I don't know of any aftermarket struts that are CATS-compliant.
Old Jun 2, 2022 | 09:39 AM
Eric's XJR's Avatar
Default bc racing
I converted to bc racing coils with the Swift spring option. I am very happy with these. These shocks are adjustable both for ride height and stiffness.
https://shop.bcracing-na.com/product...86316888#pid=2
Old Jun 3, 2022 | 08:01 AM
Panelhead's Avatar
Keep looking at Maxpeedingrods.com. They show two versions of the coil-overs. They recommended the track version for a XJR. Fully adjustable for spring rate (ride height) and rebound dampening.
They have air struts too. But either language conversion issues or lack of knowledge on their end makes the active dampening situation doubtful. Says variable dampening, but do not know if electronic, says inductive signal.
ArabianKnight
Mar 21, 2021 08:33 AM
mbclubph
Jul 7, 2015 11:48 AM
nick5125
Jan 10, 2015 09:27 AM
danveenstra
Sep 2, 2014 05:57 PM
