thermostat housing torques ?
Old Aug 18, 2023 | 10:26 AM
nebelfuerst's Avatar
Default thermostat housing torques ?
I need to swap my thermostat housing and I also will try to swap the engine inlet part.
Some threads suggest to tighten the screws "snugly", but is there an offical torque value available ?
I searched through Jtis but I didn't find how to swap the thermost housing, only the thermostat itself.
Old Aug 18, 2023 | 03:00 PM
Thomas-S.'s Avatar
Look here:
https://www.jaguarforums.com/forum/x...enance-246865/
21. Workshop manual - complete
It should be page 2310 of the PDF: Section303-03A, Engine Cooling. The first part is "specifications", where you will find the torque specifications, as well.
Best regards,
Thomas
Old Aug 19, 2023 | 10:32 AM
Thanks for guiding me.
I'm still not sure, whether "Thermostat housing retaining bolts" also applies to the bolts, which go into the engine block, or it's just the three screws to open the "triangle" which contains the thermostat.
Old Aug 19, 2023 | 10:47 AM
Update:
On page 1436, there is "Thermostat housing retaining bolts = 10NM", so I now just go with 9NM to be save.
Old Aug 19, 2023 | 02:43 PM
Thomas-S.'s Avatar
I don't think that 9 or 10 NM makes such a big difference, but it's funny that Jaguar contradicts itself...
"Thermostat housing retaining bolts" are exactly what the name says, so the ones that you are looking for.
If you read the instructions for replacing the thermostat, you can see that the torque for the bolts is explicitly mentioned there, and is the same as for the thermostat housing retaining bolts.
Best regards,
Thomas
Old Aug 20, 2023 | 02:58 AM
But what is the name of the screws with the green lines ?
( These go into the engine block, so they are those, who scare me )
Old Aug 20, 2023 | 03:05 AM
Thomas-S.'s Avatar
Those are the Thermostat housing retaining bolts, the ones that fix the thermostat housing to the engine. In any case, 9 or 10 NM are a minimum torque with which you will not damage anything.
Best regards,
Thomas
Old Aug 20, 2023 | 10:00 PM
abonano's Avatar
Go 9 or 10Nm on all bolts in that area.
mpasiuk
Jul 29, 2023 09:58 AM
Hazmat1075
Oct 21, 2022 09:09 AM
tbaxl
Apr 21, 2021 04:31 PM
Stamford
Aug 23, 2020 01:40 PM
ez64
Jul 25, 2011 10:38 AM
