Transmission shift jerky, 1st to 2nd
Old Aug 3, 2023 | 11:32 AM
JDog's Avatar
Default Transmission shift jerky, 1st to 2nd
Hello Everyone:
I know this has been answered before but I could use your help. The VDP 2005 70K miles that I am restoring for my wife has a harsh shift between 1st and 2nd. After my research, I think I need to change the trans fluid and filter. Question 1: should I just go ahead and replace the solenoids, rubber sleeves, with this change? Question 2: If I change the trans fluid and filter, do I reset or flash the trans also? Mechanic wants $700 to change trans oil and filter, extra $140 to flash new adaption of trans. Final Question: Or do I just got for it and just rebuild everything including flash, solenoids, rubber sleeves and be done with it. I am worried that if I just change the trans oil and filter, I might have to go back and have the complete trans job done again with the solenoids and sleeves, flash. Your thoughts.
Joe
Old Aug 4, 2023 | 01:47 PM
clubairth1's Avatar
Community Influencer
Before you do anything.
Do you have any codes and have you checked?
I would check fluid level before going any farther. Just rule out some simple stuff first.
Old Aug 4, 2023 | 03:54 PM
Wingrider's Avatar
+1 On codes, & the fluid level
Katlover
May 28, 2023 12:40 AM
magnum454
Mar 12, 2018 09:32 PM
ukester
Jul 11, 2013 05:01 PM
devanwon
Oct 30, 2008 10:39 PM
