Transmission / starting
Old Oct 8, 2020 | 12:39 PM
haroldpeacocksr's Avatar
Question Transmission / starting
1996 XJR. Car wouldn't start; (no power of any kind) If I put it into park "hard" then sometimes it worked. I was advised to replace the Transmission Decoder. a small 3" plastic unit with a slider in it mounted under the shift lever panel on the side. This resolved the problem, temporally, now I have a new problem, the mechanic that did the work didn't do the job correctly, now the shifting mechanism is all out of whack. I called the Jag dealer in Seattle and they don't work on this older car (96) and neither do the two garages they recommended. . .So! Does anyone know a mechanic/garage within a 100 /200miles of Tacoma that I could take my XJR too?. . ."HELP"!
Old Oct 8, 2020 | 02:43 PM
Partick the Cat's Avatar
A 1996 XJ6 is an X300. This subforum is for the X350/358 which was 2003-09.
The subforum you want is https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/
haroldpeacocksr
Oct 9, 2020 02:54 PM
jagskiguy
Oct 24, 2018 01:25 PM
Shane8362
Sep 6, 2012 06:56 PM
Shane8362
Aug 27, 2012 06:49 AM
