Valve body Plug Leaking
Old Aug 3, 2013 | 10:29 PM
wjhughes420384's Avatar
Default Valve body Plug Leaking
on my 2004 XJ8 the plug on the valve body in the tranny appears to be leaking transmission fluid right through a few of the pins causing all kinds of fault codes. Has anyone ever heard of this? Can the plug be fixed?
Old Aug 4, 2013 | 03:47 PM
Fraser Mitchell's Avatar
It's a common fault, and needs a new seal putting in. The seal is cheap the main cost is labour. What miles on the car ? It might be time to change the fluid and filter, and the seal can then be done at the same time. You are right about the pins and fault codes; they will all have to be cleaned up if the leak is a bad'un.
Old Aug 4, 2013 | 05:15 PM
Great, it has 127K miles, I was hoping there was a seal. I did just have the fluid changed and I was afraid that it loosened something that was being sealed by the sludge. I have changed the fluid every year.
do you have to remove the valve body to replace the seal?
Old Aug 7, 2013 | 10:32 AM
oldmots's Avatar
The sealing sleeve has o rings that eventually leak. It is locked on the inside of the tranny, so the plastic pan/filter has to be removed to do the job. The sealing sleeve is available from THE CTSC online.
bamforp
Aug 14, 2024 05:36 PM
Gus
Oct 15, 2019 12:29 PM
XJsc-guy
Nov 23, 2015 01:56 PM
sogood
Sep 15, 2015 07:35 AM
Bones
Sep 8, 2015 08:34 PM
