Vehicle Too Low
Old Feb 16, 2014 | 12:37 PM
hreeves's Avatar
Default Vehicle Too Low
My 2004 XJ8 w/ 174k miles has "Vehicle Too Low" warning light but not ~air system fault" warning. Dealer has indicated struts need replaced and maybe compressor. If air compressor is ok, I might replace struts with Arnotts air struts -- but if air compressor is also bad, I would save money and delete the air system and go with the coil-over Arnott struts that cost <$1,400, Appreciate any thoughts/insights on how to confirm air compressor status and strut replacement options. Threads I read about coil-over's look positive.
Old Feb 16, 2014 | 01:11 PM
Welcome to the forum hreeves,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 16, 2014 | 02:36 PM
rosskuhns's Avatar
Here's a thread I wrote up with all your options, links and pricing:
https://www.jaguarforums.com/forum/x...thread-111271/
Welcome to the forum!
Old Feb 16, 2014 | 03:30 PM
meirion1's Avatar
Check for air leaks with soapy water around the air line fittings at the top of the
front struts and in the circular 'hole' in that area.
Height sensor failure is possible but a leak more likely IMO.
Methinks sensors are Hall effect hence they don't wear like a potentiometer
Wolfy
May 28, 2024 08:06 AM
Mugatu
22
Jun 23, 2020 01:50 PM
scooternva
19
Oct 27, 2015 02:14 PM
redrover41
23
Sep 25, 2015 01:33 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
