vibration (resonance)
Old Feb 8, 2021 | 05:15 AM
Jean83's Avatar
Default vibration (resonance)
Good morning all,
There is a vibration (resonance) in the passenger compartment when the engine is in operation at a standstill or not between 1200 and 1400 rpm to be precise (so it does not come from the driveshaft, the axle and wheels) .
The Jag X350 from 2006 to 225000km, I thought that it could come from one of the 2 hydraulic engine mounts or that of the BVA.
What do you think ?
Otherwise I was also thinking of the Damper pulley ....
Are there systematic exchanges to be made on the side of these coins?
Thank you for your help.
Jeans
Bonjour à tous,
Il y a une vibration (résonance) dans l'habitacle lorsque le moteur est en fonctionnement à l'arrêt ou pas entre 1200 et 1400 tr/mn pour être précis ( donc cela ne vient pas de l'arbre de transmission, du pont et des roues) .
La Jag X350 de 2006 à 225000km, je pensais que cela pourrait provenir d'un des 2 supports moteur Hydrauliques ou celui de la BVA.
Qu'en pensez-vous ?
Sinon je pensais aussi à la poulie Damper....
Y-a-t-il des échanges systématiques à faire du côté de ces pièces ?
Merci de votre aide.
Jean
Old Feb 15, 2021 | 08:09 AM
OldKarz's Avatar
What are your LTFTs? If you have a slightly leaky injector it may make idle rough but smooth out at higher RPM.
Old Feb 15, 2021 | 08:21 AM
Jean83's Avatar
Hello Oldkarz,
Thank you for your reply,
The slowdown is stable (rev counter needle stable)
John
Bonjour Oldkarz,
Merci de votre réponse,
Le ralentit est stable ( aiguille du compte tour stable)
Jean
Old Feb 15, 2021 | 09:14 AM
motorcarman's Avatar
The only thing that came to mind was a TSB from long ago.
Old Feb 15, 2021 | 10:54 AM
OldKarz's Avatar
Yes, your RPM would be stable. The computer will adjust for the extra fuel to the proper RPM. Your engine would vibrate at 1/2 of the RPM value.
semorex
Jun 12, 2020 08:47 AM
JimSTR
19
Feb 3, 2020 04:43 PM
Dan_NL
Nov 21, 2019 04:43 PM
vlaicu
Sep 3, 2019 01:10 PM
MarkyUK
Aug 23, 2019 10:39 PM
