WANTED: Arnott Resistor for AS-2710 damper see picture
Old Nov 1, 2019 | 04:41 PM
djpxk8's Avatar
Angry WANTED: Arnott Resistor for AS-2710 damper see picture
The resistor in my 2004 XJ8 Arnott, AS-2710, rear damper has gone Open Circuit and I need to replace it. I have attached 2 pictures of the resistor.
I called Arnott and they no longer sell just the resistor, therefore if ANYONE has replaced an Arnott AS-2710 damper that no longer works, I would love to buy the resistor from you!!!
Any help would be appreciated, even scrap dealers in Florida where I might find one??
Old Nov 1, 2019 | 06:06 PM
Panelhead's Avatar
Default I had a similar issue
I measured the dc resistance of a set of active shocks for a Suburban. Had to double it. But fault came back. Had used a 5 watt resistor. When to a 25 watt. No more. Seems like the GMshocks needed a 22 ohm.
The picture does not identify the resistor. Which component is it? None look like a resistor.
Old Nov 1, 2019 | 08:13 PM
Brewster411's Avatar
I've got some old busted Suncore front struts. The resistor might be the same. I have them in storage, but I'll check next time I get a chance.
Old Nov 1, 2019 | 09:14 PM
djpxk8's Avatar
The resistor is the part that is covered in white tape, and fits into the top of the Arnott damper.
Old Nov 1, 2019 | 09:15 PM
djpxk8's Avatar
Thank you appreciate your help!
Old Nov 2, 2019 | 07:55 AM
Wingrider's Avatar
You may be forced to repair yours, a computer repair person maybe able to replace the resistor for you.
hisport
Oct 31, 2018 03:07 PM
sslaugh711
20
Feb 3, 2017 12:59 PM
Jagfrenchie
Jun 16, 2016 11:55 AM
Anxious Jim
Jan 27, 2014 01:10 PM
kbeachy
Jan 25, 2014 06:43 PM
