water pump
Old Jan 6, 2022 | 10:48 AM
MaxTorq's Avatar
Default water pump
hello again,
is my new beck/arnley water pump suppose to have an O ring ?
it came with a metal seal ? do i use an rtv on this metal gasket ?
all input is appreciated
max
Old Jan 6, 2022 | 11:02 AM
NBCat's Avatar
Does the metal gasket have a silicone bead on both sides?
Old Jan 6, 2022 | 11:06 AM
Wingrider's Avatar
No sealant used on either of mine, they came with the rubber & metal gasket
Old Jan 6, 2022 | 11:08 AM
MaxTorq's Avatar
no, just an all metal gasket with an embossed ring stamped into the metal
Old Jan 6, 2022 | 11:11 AM
NBCat's Avatar
Do not use any type of sealant. Fill the cooling system with DEXCOOL and follow bleed procedure in the Workshop Manual.
Old Jan 6, 2022 | 11:12 AM
NBCat's Avatar
Here is a link to the X350 Workshop Manual:
https://www.dropbox.com/s/xl1qtf4hwt...anual.pdf?dl=0
Old Jan 6, 2022 | 11:31 AM
MaxTorq's Avatar
Originally Posted by nbcat
here is a link to the x350 workshop manual:
thank you !
StagByTriumph
Oct 8, 2020 06:34 PM
Dan R
Mar 31, 2018 10:28 AM
kccockrell
Jul 12, 2015 06:04 PM
sidescrollin
Mar 5, 2012 09:43 PM
