Water in trunk under battery
Old Sep 9, 2012 | 12:59 PM
Edv468's Avatar
Default Water in trunk under battery
Anyone have any ideas where this could be coming from, all the rubber looks like new and the carpet in the trunk is perfect.
Old Sep 10, 2012 | 09:31 AM
Flstfi's Avatar
Maybe that is where all the electrical gremlins go to pee.
Old Sep 10, 2012 | 10:45 AM
The water is in the Battery Tray?
1. definitely water - no cracks in the battery case
2. possibly spilled when the battery was topped up
3. leaking body seam (wing to floor)
4. detached drain tube
5. missing / defective rubber grommet
6. missing battery Tray fixing bolt allowing water through
Old Aug 6, 2024 | 12:40 AM
SymbolicMike's Avatar
Hello
I am having this very same problem. It's definitely water. Also it's not from the battery. Can I get some guidance as to where the detached drain tube is at?.
Old Aug 7, 2024 | 05:47 PM
meirion1's Avatar
A common fault-even had it myself years ago.
There is a TSB on leaks but I can't find it now
Old Aug 9, 2024 | 01:49 AM
Petz's Avatar
It is either the riveted seams left and right corner below window . Push on them with the thumb. . To clean up properly wipe of with alcool then use some silicone to seal.
or the water drain at the rear lights full of debris , water beeing stuck and entering through the seal into the boot. Carpet loosened lights unscrewed 3x 10mm unhook connectors inspect , clean up fit back in.
sunroof drains to the rear go down through the C pillar down past the trunk . If you take out the side carpet you csn see drain hoses in each upper rear corner
Old Aug 9, 2024 | 12:59 PM
JoeDredd's Avatar
Mine leaked from the seam on the pasenger side and it went through the AMP on its way to the spare tyre well. It didnt end well for the amp, unfortunately.
Rick L
Jul 15, 2016 10:59 AM
Pilotman11
Jan 17, 2016 08:17 PM
Michael Jeansonne
101
Nov 12, 2015 03:36 PM
Bad Cattitude
Jun 21, 2014 09:14 AM
axr6
May 25, 2014 09:52 AM
