Weak driver's side heat / heater core / now what?
Old Feb 3, 2014 | 07:27 PM
Anxious Jim's Avatar
Default Weak driver's side heat / heater core / now what?
Greetings,
About a year ago, I had the "no driver's side heat" issue and had the heater core replaced. It worked remarkably for about 2 weeks; I could practically light a match by holding it in front of the vent.
Unfortunately after about 2 weeks, the problem returned. Frankly I was so disappointed with it that I didn't even attempt it any longer. But I'd really like to put this problem to bed (as would probably a thousand other people.)
Is it possible that the new core is clogged? I wouldn't think so, but I don't know.
The mechanic "said" that he initially checked the blend doors and they worked fine (he didn't think the problem would be the heater core), so I'm thinking it's not that. Be advised that I've had some doubts about the mechanic's ability though.
How do I whip this problem once and for all? Many thanks.
Old Feb 3, 2014 | 08:52 PM
Lagonia's Avatar
Lot's of threads on this topic. I had the identical problem and I fixed it by replacing the electrically operated auxiliary water pump. It sits on the fan cowl on the right hand side of the engine right below the upper radiator hose.
The other major culprit stated in multiple threads is gel formed in the innards of the heater core rendering the heater core inoperable and in need of replacement.
Old Feb 3, 2014 | 08:55 PM
RCSnyder's Avatar
If it's still just the driver's side, yes, it is once again a clogged core. Now, the question is, why?
I postulated a couple of weeks back that my core seemed to be clogged with shards of rubber, and thought the inside of the hoses might be chaffing. Any chance you replaced one or more hose after replacing the core?
Still thinking outside the box.
99xk8guy
Sep 29, 2025 10:51 PM
02jagstype
23
Oct 23, 2022 07:03 PM
avern1
Sep 8, 2015 06:25 PM
tberg
Sep 7, 2015 07:32 AM
Dallas XK8
Sep 3, 2015 12:17 PM
